Undergrad Why can a person cycle more in a day than they can walk or run?
  • Thread starter Thread starter saddlestone-man
    Cycle
Cycling is generally more efficient than walking or running due to the mechanics of movement and energy expenditure. While cyclists must move the weight of the bike along with their body, the horizontal motion minimizes energy loss compared to the vertical motion involved in walking and running. The structure of the human leg allows for more efficient energy use when cycling, as it doesn't have to support body weight in the same way. Additionally, bicycles benefit from gear systems that optimize leg motion and maintain speed with less effort, particularly on inclines. Overall, these factors contribute to cyclists being able to cover greater distances in less time than runners or walkers.
saddlestone-man
TL;DR
What's the physics behind the efficiency of cycling versus walking or running?
Hello All
Numbers vary, but the consensus is that an average person can cycle much further in a given time than they can walk or run. The world record for running is about 300km in 24 hours, whereas the cycling record is about 900km. A more typical comparison might be that a fit athlete could run a marathon in a day (and be pretty tired at the end of it) but could probably easily cycle 100 miles in a day.
Why is this so? The cyclist has to move the weight of the bike over the distance as well as his/her body, so isn't the total work needed more on a bike than when running?
I'm assuming that the start and end points are at the same altitude, so that the cyclist can't just free-wheel the whole distance.
best regards ... Stef
Likes Lnewqban
saddlestone-man said:
Summary:: What's the physics behind the efficiency of cycling versus walking or running?
It's all to do with a thing called the wheel.
Likes sreerajt, sophiecentaur, vela and 3 others
None of these cost energy: weight is a vertical force and the motion is horzontal So ##\vec F\cdot\vec s = 0\ ##.
(this is also true for walking!)
Likes docnet
Can you explain this in terms of Mechanics?
It doesn't take any energy to continue moving with constant speed (on a flat surface). All the energy you use walking or cycling at a constant speed is through mechanical inefficieny. A wheel has almost no friction or resistance and conserves linear momentum.
Likes Demystifier and docnet
Do you mean over the horizontal distance traveled? Check out the exact definition of work. What do you get if force and displacement are at 90°?
https://en.wikipedia.org/wiki/Work_(physics)
Walking and running involves moving the center of mass up against gravity in each cycle, which happens much less in cycling. Instead you have some rolling resistance, which can be pretty high too (like on sand) but can also be made very low on hard surfaces.
Likes Klystron and jrmichler
One answer may be in the structure of the human leg. It has to support the weight of the person (which on a bike is supported by the seat via the buttocks) and propel the body along when walking and running.
Once it's relieved of having to support weight, perhaps it's more efficient at producing the rotation needed to drive the pedals of the bike?
Likes Lnewqban
Why do you have to drive the pedals to cycle at constant speed?
Likes docnet
I feel like you didn't absorb what the others told you regarding the definition of "work".
Likes Vanadium 50
That's part of it. Muscles use energy, even if they don't lift the center of mass, just to generate the forces for holding it against gravity. But walking and running also involves lifting the center of mass, even on level ground.
The legs are not naturally optimized for driving pedals, but do they adapt if you do it a lot.
Likes Lnewqban
Walking is a complex coordinated group of movements, contractions and extensions of muscles, as well as accelerations of bones and joints.
Being that complicated makes it more flexible in terms of terrain irregularities that it can take, as well as climbing and jumping capabilities respect to cycling.
Please, see:
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC3223624/pdf/rsif20110182.pdf
:cool:
Do note that in walking and running there is an up/down motion with each step.
Likes russ_watters
TThis is only true when cycling on hard surfaces. So after you've put a lot of energy in making the road first. Try this comparison in the woods.
  • Skeptical
Likes PeroK
Yes, and you swing your arms too. Yet another (...) motion cyclists try to avoid :biggrin:
Likes docnet
The key, in my opinion, is the "strike" in walking. That is when the heal of your lead foot touches down and your foot and leg is forced to absorb the downward momentum of your body. Human muscles do not regenerate energy. The impact energy is lost. *poof*.
By contrast, in a bicycle there is no impact energy to lose. You can coast.
Then too, as I think has been pointed out, human muscles use energy just to maintain tension. To the extent that you walk in a smooth stride with legs slightly bent, you'll be wasting energy just supporting yourself against gravity.
By contrast, in a bicycle you have a seat.
Likes Klystron, PeroK and russ_watters
A reasonable comparison, perhaps, is skating and cycling. Skates on ice also allow you to maintain your momentum with no impact.
Likes jack action, docnet and jbriggs444
On a bike you can gain speed on a downhill section knowing that you will get most of that kinetic energy back as you coast either on a subsequent flat or uphill section. I don't think you can reproduce this effect if you are running.
Likes Demystifier
Good point. I wonder what the comparable "record" is for skating for 24 hours. Presumably it would around some large frozen lake...
Likes docnet
Unless you fall down -- then there's an impact :oldbiggrin:
Likes docnet and russ_watters
One that is thawing, which will ensure the skater is extra motivated. :wink:
Seriously, there is something called "Nordic skating", which is long-distance ice skating. I don't know much about it; it's a Canadian thing.
Likes docnet and berkeman
I'll think you'll find, maybe not surprisingly, that it is originally a Nordic thing particularly popular in Sweden. ;) There is a similar activity om the Netherlands where they distance skate on the canals.
Other activities that could be interesting to use as a comparison is inline skating and roller skiing.
Cross country skiing is also a interesting data point.
Likes berkeman
Nonsense. Almost all kinetic energy is dissipated in wind resistance.
Likes docnet
Good point. :smile:
https://cyclingtips.com/wp-content/uploads/2021/02/supertuck.jpg
A face plant on ice is far less painful than a face plant on pavement. On ice it's WHAM and slide, while on pavement it's WHAM and sudden stop with skin removal. I learned this a few years ago when I caught my toe while trying for speed on my ice skates. Right in front of the local bar. More than once.
Likes russ_watters
But one seldom stabs oneself in the butt when doing a faceplant on pavement. Don't ask me how I know this...
  • Haha
Likes docnet, berkeman and russ_watters
Along with the aforementioned efficiencies of riding a bicycle on pavement over walking and running, bicycle gear systems also improve efficiency, allowing comfortable uniform leg motions over varying terrain. Within reasonable incline angles one can down shift to lower gears to maintain roughly similar exercise level where a pedestrian would have to expend extra effort lifting up an incline.
Elliptical front gearwheels, smooth ball bearings, freewheeling plus other innovations also improve bicycling experience over walking and running. I imagine roller skates, skateboards and possibly unpowered scooters fall somewhere between bicycles and walking/running; providing some improvement on smooth pavement.
Likes A.T. and Drakkith
Only for very short segments, right after each other. Otherwise you dissipate the energy by drag.
Right, running downhill can even use more energy than on level ground.
Likes sophiecentaur
A small amount of energy can be recovered, because the tendons act like springs. But this is more relevant in running and in other animals. The bicycle avoids the impact completely on smooth level ground.
Likes Spinnor and sophiecentaur
Yes, this is an important point. When you try to run fast, it becomes very inefficient in terms of energy per distance, because muscles have limited contraction speeds and accelerating the legs forwards in the swing phase also uses more energy. Gearing (even if fixed to a sensible value) allows you to cover more distance per day on a bicycle, because you move faster while your muscles work at their close to optimal physiological speeds.
Likes Klystron
  • · Replies 21 ·
32K
  • · Replies 66 ·
  • · Replies 18 ·
  • · Replies 66 ·
