I Why Can Tzz in Maxwell's Stress Tensor Be Non-Zero in Electrostatics?
Tzz in Maxwell's stress tensor indicates a force per unit area in the z direction, even when the electric field along z is zero in electrostatics. This component reflects the interaction of the electromagnetic field on opposite sides of a surface, rather than a force acting on a charge distribution. The analogy of a box demonstrates that applying forces in the x and y directions can still create pressure in the z direction on the top and bottom surfaces. This highlights the complexity of electromagnetic forces and their effects in electrostatic conditions. Understanding this concept is crucial for analyzing forces in electromagnetic fields.
member 743765
In summary Tzz in maxwells stress tensor represents a force per unit area in the z direction acting on an area element that is oriented along the z direction also why it could be non zero eventhough the electric field along z is zero and I'm talking here in electrostatic
It is not a force on a charge distribution. It is the force of the EM field on one side of the surface acting on the EM field on the other side.
Can I use the analogy with a box when you apply forces on x and y directions on its sides but not on the top and bottom there will be pressure on the z direction on the top and bottom
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
