Why can't we remove Ampere from being base unit?
In summary, an ampere is a unit of current that has the same physical meaning as now, where the current which two parallel conductor would generate a force of 1N on each other. The new definition of an ampere is a derived unit instead, based on the value of the constant K'.
tsoits
1) Analogy in F = ma
From experiment, we find that
[itex]F = k m a[/itex]
and we deliberately choose [itex]k = 1[/itex] (dimensionaless) and thus we define the unit Newton, a derived unit.​
2) In the definition of ampere, it is in terms of the force per unit length between two straight parallel conductors having equal current.
[itex]f = K I^2 / r[/itex]
One ampere is defined for
[itex]I = K' \sqrt{f r}[/itex]
As we know today, the constant [itex]K'[/itex], has dimensions ([itex]A/ \sqrt{N}[/itex]).
What if we instead take K' as dimensionless, just like the constant in Newton's 1st law?
In this case, the new Ampere 1 A would have the same dimension as [itex]\sqrt{N}[/itex].
In other words, this new ampere is a derived unit instead?
3) What's bad about this new definition?
I'm quite sure someone must have thought about this, or I must have made some terrible mistake. But as I can't find any references, here's what I can come up with so far:
a) [itex]\mu_0[/itex] becomes dimensionless. So the unit of [itex]\epsilon_0[/itex] has to be changed too (related to speed of light).
b) can't think of it yet..
Shouldn't there be a more fundamental reason for this?​
Ampere is just a name, a word. Current is the flow of charge over time. So whatever unit we choose to use for current, it must still retain the same physical meaning of C/s. We cannot assume that the proportionality constant between current and the square root of force to be dimensionless because then we would be unable to have a unit that relates the amount of charge per unit time. Now the value of that proportionality constant is something that we have the freedom of choosing, but the dimensionality has to be fixed to retain physical meaning.
Born2bwire said:
Ampere is just a name, a word. Current is the flow of charge over time. So whatever unit we choose to use for current, it must still retain the same physical meaning of C/s. We cannot assume that the proportionality constant between current and the square root of the product of distance and force to be dimensionless because then we would be unable to have a unit that relates the amount of charge per unit time. Now the value of that proportionality constant is something that we have the freedom of choosing, but the dimensionality has to be fixed to retain physical meaning.
In my equation, the physical meaning of ampere is not altered. It is still having exactly the same definition as now:
As long as there is no inconsistency in the definition, there shouldn't be problem for its physical relation with charge. After all, charge is just a derived quantity of current, which is a base quantity.
PS Thanks for your input. I'm defending my argument not because I believe it's correct; rather, I do believe it's wrong, just that I have yet found out why...
How can you say that the physical meaning is not altered?
Originally we have something like this:
[tex] A = K*\sqrt{F} [/tex]
where F is units of N. Now, whatever value we choose for K, K MUST have units of [itex]\frac{C}{s\sqrt{N}}[/itex]. The definition of an Ampere being the X Newtons of force between two infinite wires that are Y meters apart only determines the magnitude of the constant [itex]K[/itex] above. It does not determine the units of [itex]K[/itex], that has to be fixed so that the units of A agrees with the physical definition of A.
So I don't know what you are arguing here. If you mean that we can change the value of K, then sure, we can redefine the definition of Ampere so that the K is different (right now we define K such that the distance and forces involved are 1 m and 1 N respectively) but the units of K are fixed.
Thanks. Of course here I'm not talking about the value, but the dimension.
Let me put it this way.
Why can't we define [itex]A = \frac{C}{s} = {\sqrt{N}}[/itex] ?
What kind of inconsistency would occur?
Currently, a Newton is a unit derived from the kilogram, which is based on an international prototype kilogram (and some backup copies).
The ampere could be a derived unit from coulumb, based on the standard
1 elementary charge = 1 / (1.602176565(35) x 10-19) coulomb
or about
1 coulomb = 6.2415093 ×1018 elemetary charges
This could make the kilogram a derived unit, but I doubt there's any existing method to accurately measure a Newton based on the current definition of an ampere, which is the current flowing in each of two parallel wires in a vacuum spaced 1 meter apart producing a force per meter of exactly
2 x 10-7 netwons / meter
I would say that the inconsistency is that the Ampere is a base unit. It is not derived from other units like the Newton. So to me, it does not make sense for someone to say that an Ampere is [itex]\sqrt{kg-m}/s[/itex]. The kg, m and s are base units as is the Ampere.
Thanks! This goes back to my original question in the title:
"Why is Ampere a base unit, rather than a derived unit?"
I thought about this because I noticed that while other base units' definition are quite self explanatory, the definition of Ampere seems to be derived from Newton.
Hi tsoits,
It sounds like you are thinking along the lines of what is done in the Gaussian cgs system of units:
http://en.wikipedia.org/wiki/Gaussian_units
You certainly can set up a system of units (like the Gaussian cgs units) where the electrical quantities are expressed purely in terms of the mechanical quantities. There is some appeal to doing that since it reduces your required number of fundamental dimensionful parameters and it does not unncecssarily add new base units.
However, Born2bwire is 100% correct in his assertion that the physical meaning is altered. You can set up a consistent set of units in this manner but the equations for the physical laws are different in this system of units:
http://en.wikipedia.org/wiki/Gaussian_units#List_of_equations
Note that there are no factors of vacuum permittivity or permeability in Gaussian cgs units. Also, there are additional factors of c in some places, and the factors of pi are moved around.
Thanks DaleSpam, this is exactly the answer I want!
It's a pity that the copy of Jackson's I got is no longer using cgs; so I just barely heard of the name cgs before without knowing such a consequence.
Thanks also to Born2bwire =)
Related to Why can't we remove Ampere from being base unit?
1. Why is Ampere considered a base unit?
Ampere is considered a base unit because it is one of the seven fundamental SI units that are used to define all other units of measurement. It is considered a base unit because it cannot be broken down into smaller units and is essential in defining other electrical units such as voltage and resistance.
2. Can Ampere be replaced with a more modern unit?
No, Ampere cannot be replaced with a more modern unit as it is a fundamental unit of measurement and is deeply ingrained in scientific and engineering practices and calculations. Additionally, changing a base unit would require a global consensus and significant effort to redefine all other units of measurement that are based on Ampere.
3. What would happen if Ampere was removed as a base unit?
If Ampere was removed as a base unit, it would create chaos and confusion in the scientific and engineering communities. All existing measurements and calculations that use Ampere as a base unit would have to be redefined, which would be a daunting task. It would also affect the consistency and accuracy of all electrical measurements.
4. Is there a historical significance to Ampere being a base unit?
Yes, there is a historical significance to Ampere being a base unit. It was named after the French physicist Andre-Marie Ampere, who made significant contributions to the study of electricity and magnetism. Ampere's laws and theories laid the foundation for the development of Ampere as a base unit.
5. Are there any alternatives to using Ampere as a base unit?
Currently, there are no alternatives to using Ampere as a base unit. It is considered the most appropriate unit for measuring electrical current and is widely accepted and used in scientific and engineering fields. However, there have been discussions about potentially replacing Ampere with a more precise unit in the future, but this would require a global consensus and significant research and development.
  • Electromagnetism
  • Other Physics Topics
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
