Why colonize Mars and not the Moon?
  • Thread starter lifeonmercury
  • Tags
    Mars Moon
  • Featured
In summary, Mars is a better option for human survival than the Moon because it has a day/night cycle similar to Earth, it has a ready supply of water, and it has a higher gravity. Colonizing Mars or the Moon may be fantasy, but it is a better option than extinction on Earth.
  • #771
mfb said:
Solar panels are considered as well. They have a nice power to mass ratio
Yes, apparently 1.7 tons of solar panels http://www.uapress.arizona.edu/onlinebks/ResourcesNearEarthSpace/resources30.pdf to accomplish the same fuel production mission as the four ton nuclear reactor in Mars Direct.
and space is not an issue.
Same source has an array 1850 m^2, less than on the ISS. Space craft arrays don't need much structural support, but one on Mars would need some. Assuming, 2 cm thick strings of cells, that's 37 m^3 of solar panels. Its not clear to me how that volume competes with the reactor on Mars transit.
Astronomy news on Phys.org
  • #772
mfb said:
Solar panels are considered as well. They have a nice power to mass ratio and space is not an issue.
I would have thought solar panels would be an ideal solution. Totally flexible modular design where a single problem with nuclear generation would mean no electricity supply. And we wouldn't want to mess up the Martial environment die to a crash or other unforeseen accident.
The issue of batteries for night time is not there if the panels are for fuel production. They deffo get my vote.
  • #773
mheslep said:
H20 is only trace in the air, except for small periods near the poles.
On Earth, CO2 is only 0.04% in the air. Look at any tree. Its carbon came _entirely_ from that CO2.
  • #774
Was that 1% energy efficient conversion?
The leaf does gas separation by conversion from CO2 to carbonic acid, H2CO3. Martians can use minerals that react with water. However, if there is already a 2 story sand dune of hydrated mineral nearby then it is easier to use a bulldozer instead stressing the distillation plant.
  • #775
We're discussing a very involved industrial process here, for which the small details affect the choice of the optimum system. It's hardly worth discussing the beauty contest without much more information about the real situation and the actual costs involved.
  • #776
Everything has to be redundant. No one would rely on a single nuclear reactor - you would send at least two or three, where the failure of one or even two is not mission-critical. Same for the electronics for solar panels.
Batteries are useful if no nuclear reactor is present - you need electricity at night, and burning fuel for that has a bad efficiency.
  • #777
I get all that; redundancy goes without saying, along with loads of reconfigurability. A solar farm would be producing much more fuel than would need to be stored in the basic overnight batteries. The best economy is to run with minimal dark time requirements and a big proportion of the solar output would go towards rocket fuel and daytime manufacturing activity. Vast thermal storage systems would be the way to provide heating. Life would revolve around such regimes - which is why I have always said that life on Mars would be no picnic ( same as in the Antarctic stations but much worse - no penguins to provide light relief. I would foresee the need for a lot of Psychoanalyists up there.
  • #778
I know. However, the need of plant life for water and CO2 is considerably different. A mature tree might uptake .1 or .2 kg of CO2 per day in its growing season, but use almost half a ton of daily water. I doubt collecting the scant water vapor in the Martian atmosphere is effective compared to mining the soil for ice.
One might well send a single reactor for the unmanned fuel production mission.
Supposedly the dust storms encountered by the rovers blocked up to 99% of sunlight during the storm, and the dust cover remaining afterwards significantly reduced power. I doubt solar (plus batteries) is suitable, either for a manned mission with 24 power needs or an earlier unmanned fuel production mission that might be permanently impaired.
https://en.m.wikipedia.org/wiki/Spirit_(rover)#Global_dust_storm_and_Home_Plate
There have been several unmanned Mars mission accidents strewn around the planet, such as the Mars Polar Lander impact. There will be more. Curiosity's sky crane retro rocket was by design destroyed on the surface after landing Curiosity.
https://marsmobile.jpl.nasa.gov/msl/mission/technology/insituexploration/edl/skycrane/
  • #779
. . . .but none involving nuclear materials, which was what my post was referring to.
  • #780
How are nuclear materials, even if some escaped from a tiny reactor, harmful to the Martian environment? Mars surface radiation is 30 uSv/ hr, 120 times that of Earth background levels.
Likes anorlunda
  • #781
This would result in almost five time the yearly maximum permissible dose for radiation worker on Earth. I have seen figures of abut 10uS/hr. for ISS so the astronauts can be brought back before them reach the 0.05Sv limit. How will the Mars surface dose let alone the transit dose to and from Mars be justified?
  • #782
Even then you have to shift everything by 2 years if there is a problem with the reactor.
99% of direct sunlight. There is also indirect sunlight, especially with so much dust around.. About 1/2, with a worst case of about 1/4 light left, we had the numbers earlier in the thread.
30µSv/hr for unshielded components (number from above, didn't check it). Humans would be shielded at least by a space suit, but most of the time by their habitat, and probably some regolith on top of that.
  • #784
First, the 30 µSv/hr (263 mSv/yr) is on the surface, is not a dose, and is not inside a vac suit/habitation/vehicle where some amount of the radiation won't penetrate. Second, the US radiation worker limit is 100 mSv/yr, though Fukushima workers use 250 mSv/yr. Third, these limits are in terms of dose, absorbed by the body, not simply incident on the skin. The ESA has a total career limit of 1000 mSv for its astronauts, which gives a "5-percent increase in lifetime fatal cancer risk".
  • #785
mfb said:
...Even then you have to shift everything by 2 years if there is a problem with the reactor..
Redundancy should be used with a high bar of overall improved mission performance and reliability. Adding another 4.5 tons of a #2 reactor means at least 4.5 tons less of something else, in a context where every kg on board has a high or critical value. Often, it will be better to take one of something made very reliably with lots of performance margin and well tested. After all, I've not seen it suggested that two loads of hydrogen fuel are transported in case the first is lost.
mfb said:
... the thread.30µSv/hr for unshielded components (number from above, didn't check it).
27 µSv/hr from here, via the instrument on Curiosity: "RAD's data show that astronauts exploring the Martian surface would accumulate about 0.64 millisieverts of radiation per day."
I had 29 uSv/hr from somewhere else which I can't recall.
  • #786
Use two 2.25 ton reactors, unless they scale too bad for that. If one fails, you make slower progress, but at least you don't lose all power in the station. In particular, you can keep cooling the fuel you already have, and if the failure doesn't happen too early you still might get the job done in time.
A nuclear reactor is more prone to issues than a simple fuel tank.
stefan r said:
There is a high risk, but the cancer risk is not the largest part.
  • #787
They probably want one power supply for the main site and one with the rover. Going to Mars and sitting in a hole does not sound like the inspiring adventure people were hoping for.
  • #788
Since the skin is rather insensitive to radiation exposure it is the deeper "critical organs" that is of more interest. The 30 uSv/hr is most likely due to rather penetrating radiation to assess the dose to these organs. I think the ISS dose data indicates that the space suit provide minimal protection.
Actually it is what is referred to as a dose equivalent, the standard quantity used in radiation safety programs. Dose equivalence takes into account, as a rather rough approximation, the relative biological effects of different types of radiation. It differs from absorbed dose which only determines the energy per gram deposited in tissue. The rate of deposition of energy as measure by the Linear Energy Transfer produces increasing biological effects as it increases.
When did we increase the MPD? https://www.osha.gov/SLTC/radiationionizing/introtoionizing/ionizingattachmentsix.html OSHA still lists it at 50 mSv/year, i.e. 5 Rem/yr in the old units listed on their site.
Just to clarify this statement at 1 Sv whole body dose equivalent the lifetime probability of cancer is 0.05. The lifetime probability of cancers from non radiation causes is about 0.39..The bottom line is that we can (must) relax the dose limits for a few brave explorers for relatively short stays. Will tourists be exempt from the MPD requirement for the general public currently at 0.5mSv/year? What about large populations for a lifetime especially those born there? Actually not a problem in desperate times with desperate situations we must take desperate measures,
Initially living accommodations will be on the surface similar to ISS I would suppose. Living underground at least 12 feet to get the equivalent protection of our atmosphere will probably require heavy machinery complicating the establishment of a colony.
  • #789
I like that idea for the prelim-unmanned fuel production mission, when time has little cost in the case of a single failure. On a manned mission, I doubt two-half size reactors prevent calamity if up to twice the food and other supplies are required for the period on the surface.
A nuclear reactor is more prone to issues than a simple fuel tank..
I don't know that this is the case for a simplified 100 kW reactor on a Mars mission: sealed, no-refuel of fuel removal. I don't believe many radioisotope power generators have failed in the history of spacecraft , relative to fuel/oxidizer tanks. A single spark won't destroy a reactor and everything around it, as a spark in an O2 tank might do.
  • #790
gleem said:
The 30 uSv/hr is most likely due to rather penetrating radiation ...
How do you know the radiation type? Gammas, neutrons are highly penetrating, alphas, protons, not as much. I don't know the make up, other than that cosmic is higher energy than solar.
Yes, my mistake, max annual whole body dose is 50 mSv.
Right, radiation of one Sv gives excess cancer risk of 5%.
For comparison, a current smoker has an excess risk of 20% (Figure 4). I would not call smokers brave.
Desperate about what, in relation to a Mars mission?
  • #791
Isn't it a bit early in the day to be making judgements like that? Is your background value consistent all over the surface?
  • #792
Radioisotope generators are not nuclear reactors. At least not the type discussed, that could power a Mars settlement.
The manned mission will need more nominal power than normally used to account for failures. There is no way to avoid that.
As Mars doesn't have a relevant magnetic field and the atmosphere is quite thin everywhere, I would not expect a strong dependence on the location. Lower points and points closer to the poles will have slightly lower dose rates.
  • #793
I don't. Whoever measured/quoted 30uSv had to make an assumption since all they could measure would be the absorbed dose with would be quoted in Grays.
Nor do I. They are tolerant of the latent risk because for the immediate perceived benefit(?). Astronauts really do not have many benefits but say for curiosity or glory if they succeed.. Sitting on top of thousands of pound of explosive chemicals or using technology that has been minimally tested does elicit a certain amount of bravery since much of the risk is imminent. The increased risk of cancer from radiation exposure is probably not even statistically significant for a few dozen persons.
I am led to believe that at some point in the probably distant future it is expected that the Earth will not be a fit place to live and humanity must be preserved at any cost. The Mars mission is the first step for the establishment of a colony for the anticipated emigration.
Remembering the small asteroid that exploded over Chelyabisk Russia might be one reason that some are thinking about our demise.
  • #794
That measurement is presumably of surface radiation levels and most of that would presumably be from space, due to the lack of magnetic field. I mentioned environmental damage and the environment goes below the surface. If nuclear materials get into the surface, the result is very different from radiation from space, which will not penetrate far below the surface. Now is the time to consider such matters and avoid over simplistic comparisons of the two risks. It's that attitude that confirms my doubts about the viability of humans Terraforming Mars, in which absolutely everything possible needs to be taken into account. It certainly hasn't been like that for Earthly development.
  • #795
Practice will tell.
In any case, this discussion is useful by highlighting (especially for the "Moon first" crowd) the issue of having various volatiles available. It's very important for any colony.
  • #796
And thin atmosphere.
Cosmic radiation creates dozens of radioisotopes in the Earth's atmosphere, and so too the surface of Mars and Ceres, which is how in part that the Dawn probe performs gamma spectroscopy on Ceres to determine it's surface composition, and to some depth.
https://en.m.wikipedia.org/wiki/Cosmic_ray#Changes_in_atmospheric_chemistry
It's that attitude that confirms my doubts about the viability of humans ...
Yes humans have flaws, one of which is dogma. For instance, to declare environmental disturbance A okay, but type B bad.
  • #797
You seem very confident that the little we know about the surface (and below) of Mars is enough to predict the effect of anything we might do to it. That is surely as much a "dogma" as any wariness I might be expressing about the possible risks. Doesn't experience of the effects of human careless treatment of Earth give you any worries about possible damage on other planets? Disturbances A and B should each be treated with care. Out record is not impressive down here and not surprising, bearing in mind the priorities that are applied.
  • #798
I pointed out the mistaken assertion that there is no radiation penetration below the surface, but I've never indicated omiscience about Mars. The discussion above was about you singling out a particular disturbance ("nuclear materials") with no particular basis.
No, not about rocks in space. Yes people have done Foolish Things, more to come. At the same time, space exploration also conjures up, "What a piece of work is a man! How noble in reason, how infinite in faculty! In form and moving how express and admirable! In action how like an angle"
The nature of life, and of exploration, is to disturb the surroundings. To focus on the trivial is to miss the disasterous.Out record is not impressive down here and not surprising, bearing in mind the priorities that are applied.[/QUOTE]
  • #799
I don't understand why we would want to look at a planet in our solar system... In order to increase the probability of human existence remaining in the universe, we need to both terraform and colonize another planet orbiting a different star. A younger star preferably.
  • #800
You are assuming that your priorities are not open to challenge then?
You seem to imply that 'enough' work has been done on establishing the situation and possible risks in Mars. I can't think of the basis for this. Humans have been aware of situations on Earth in great detail and made decisions which have been based on a selected sample of evidence, to support their cause. Do you really think that things would be different on Mars?
So Mars is just a 'rock in space'? From the title of this thread, I though we were discussing the possibility of a future home for colonists. But I guess they would not be you so you are insulated from their consequences.
I cannot get fired up by language like that, I'm afraid. Politicians dish it out all the time and it's very often the strongest when their cause is weakest. (Second Gulf War was a good example) Let's have some evidence based policies and not policy selected evidence.
  • #801
Because while sending a lot of people to Mars or the Moon ain't easy going to another star system is completely infeasible for the foreseeable future.
Likes mheslep and nikkkom
  • #802
Exploration, discovery. I don't care to live at the top of Everest or the bottom of the deap ocean, but I think it would interesting to visit.
  • #803
sophiecentaur said:
You are assuming that your priorities are not open to challenge then?...
You're responding to your last sentence in #796, which I failed to trap correctly in quotes for some reason.
  • #804
I was making assumptions about your priorities, perhaps. (I missed the \QUOTE thing.) But, from your statements, I think I have divined your priorities correctly - no?
This thread is getting very tired and we're not going to be convincing each other, are we? I would just suggest that there is more to this than 'to boldly go' and your "rocks in space" description is worrying to me.
  • #805
Why not build a HUGE space station off planet Earth and then another and then another, if survival and colonization are the goals. When we get a HUGE space station colonized and self-sustaining, then we can send these stations into deep space searching for planets that have the conditions to sustain life. Mars is a dead planet with unhospitable conditions for long term survival. To Terraform Mars would take centuries, if even possible.
21K
10K
