- #176
Stavros Kiri
- 1,064
- 849
But what about gravitational equilibrium in the solar system? Also negligible? (i.e. the perturbation)
Depends on how we want to disintegrate them. Your numbers would mean 40,000 MT for Phobos and 3,000 MT for Deimos. That is still possible. 400 and 30 Tsar bomba style (with the additional fission layer that got removed) nuclear explosions, respectively.Vanadium 50 said:Deimos and Phobos are held together not by gravity, but by chemistry. It's hard to calculate the exact binding energy, because we don't know much about the interior structure and composition, but a ballpark estimate is that you need ~400x more energy to dissociate Phobos and 1000x more to dissociate Deimos.
No matter what we do with the moons, it will have no notable effect on anything in terms of orbits. Mars has 60 million times the mass of Phobos and Deimos combined. If we bring the moons down (not trivial with angular momentum), the combined mass does not even change. If we shoot the moons away, the combined mass goes down by 1 part in 60 millions. Completely irrelevant.Stavros Kiri said:But what about gravitational equilibrium in the solar system? Also negligible? (i.e. the perturbation)
I meant more the forces from the sun and other planets to the moons etc. (that could affect the dynamics of the system - not trivial!) , not the mass itself! That could have been a problem, but may be also negligible. What do you think?mfb said:Depends on how we want to disintegrate them. Your numbers would mean 40,000 MT for Phobos and 3,000 MT for Deimos. That is still possible. 400 and 30 Tsar bomba style (with the additional fission layer that got removed) nuclear explosions, respectively.
Why don't you do some simple calculation before accepting a statement as fact.Stavros Kiri said:Thanks for correcting us on that one! (simple mechanics! ...)![]()
Just some minor "marsquakes" perhaps ...
I think you may have read my partially humorous post backwards. I' ve already accepted all that. I know mechanics. But you analysed it for the others. Thanks.256bits said:Why don't you do some simple calculation before accepting a statement as fact.
You do know the universal law of gravitation.
Pick instead of a moon revolving around a planet revolving around a star.( centre of mass of moon-planet revolving around the star )
Pick two objects of equal mass revolving around their centre of mass far from other objects.
Stop one object in its tracks wrt the centre of mass ( and a line from the COM and the object ) with a "brick wall".
Remove the brick wall - do the objects fall into one another? Does the orbits of either change? Has the COM changed in any way?
( Note: The second object will continue to have an unchanged tangential velocity at moment of impact of the first with the wall )
Stop one object in its tracks wrt to the normal to the tangential velocity of the second object so that the first object acquires the same velocity parallel to the second.
Now do the objects fall into one another? Has the COM changed in any way?
Your conclusion?
I don't understand that sentence.Stavros Kiri said:I meant more the forces from the sun and other planets to the moons etc.
The prevailing force is the sun's ...mfb said:I don't understand that sentence.
Even Mars (the whole planet) has a negligible influence on the orbits of other planets. 1/60 millionths of a negligible influence is really negligible.
Kepler orbits are closed, and all planetary orbits are stable over the lifetime of the solar system. Disturbing them a tiny bit, which happens all the time, does not matter.
There is no equilibrium in the solar system.
Please start a new thread if you want to discuss this in more detail, it seems to be off-topic here.
I am going through your references, but 1 Sv dose corresponds to a 5.5% increased lifetime risk of cancer. Describing that as "risky" is fine, but describing that as "suicide" is not an accurate statement at all and it is far from "certain".|Glitch| said:a total exposure of 1 Sv for a 30 month (6 months going to Mars, 18 months on Mars, and 6 months getting back to Earth) mission duration.
Dale said:orresponds to a 5.5% increased lifetime risk of cancer
That is truly surprising to me, but very interesting. Certainly Mars is further away in actual distance, but in a very real engineering/economic sense it is closer. In principle, you could ship cargo to Mars less expensively than to the moon since you wouldn't have to worry about cargo getting there fast like you do have to worry about with passengers.mfb said:es.
LEO -> Moon surface needs 5700 m/s.
LEO -> Mars surface with aerocapture needs ~4300 m/s, depending on the launch window.
The advantage of Mars is the atmosphere. Going back needs much lower delta_v starting from the Moon, of course. But even starting from Mars, a single stage rocket can work. The same rocket that landed on the surface, which means you just need to fuel it. And that is easier on Mars...
It was mentioned, discussed, a source was found, and the issue of dust storms looks manageable.gleem said:No one mentioned the average surface temperature is -80F or the frequent dust storms that might preclude the use of solar energy.
Does it? Absolute poverty is decreasing rapidly, life expectancy is rising nearly everywhere, often with shortening working hours, with more and more money spent on non-essential things. Crime rates go down in most places, ... It is hard to find any measure where the world isn't getting better every year.Vitro said:The cost of maintaining our society and fixing the world's problems keeps getting higher
That's, um, an entertaining thought.Algr said:By the time humans get to mars, the robots will be so advanced that there won't be any need for humans.
Maybe. Maybe not. We don't know. Stating a possible future as fact is misleading.Algr said:By the time humans get to mars, the robots will be so advanced that there won't be any need for humans.
mfb said:Stating a possible future as fact is misleading.
I still hope not ! ...rootone said:In 1000 years time ...
Meanwhile human civilizations on Earth are just interesting historical data.
mfb said:Musk's optimistic estimate is a few humans on Mars by 2026, with more coming every 26 months, reaching a population of a million and self-sufficiency around the end of this century
Then don't pretend it would be sure. That is acceptable if the probability is basically 1 ("the sun will continue to exist tomorrow"), but not otherwise ("I will win the lottery tomorrow").Algr said:That's just the nature of the future. Anything you say about it has a chance of not happening.
No one doubts that.Vanadium 50 said:There is no way to do this without transporting 10's of thousands of people every launch window.
mfb said:The first controlled powered flight was made 1903...By 1947 there were more than 10 commercial transatlantic flights per day.
lifeonmercury said:Ensuring that the colonists have an extremely high birth rate on Mars would eliminate the need to find such a large amount of volunteers to go there.
lifeonmercury said:would eliminate the need to find such a large amount of volunteers to go there.
lifeonmercury said:Sending 200,000 people
Most deserts have wells, oases, cave pools, even rivers. The Moon is HUGE! It's size, considering the probabilities, makes many things likely. We just need to find those exceptional places.mfb said:There are also traces of water in deserts. That doesn't make them swimming pools.
"Following the successful test of the launchpad abort system in May 2015, Elon Musk indicated that the Dragon capsule platform, launched on a Falcon Heavy launch vehicle, could be used to transport robotic space probes across much of the solar system, including Earth's Moon, Mars, or Jupiter's moon Europa.[37] Musk indicated that Dragon could transport 2 to 4 tonnes (4,400 to 8,800 lb) of useful payload to the surface of Mars."
Vanadium 50 said:OK, so we went from the first controlled powered flight to ten commercial transatlantic flights per day in 44 years. The first manned spaceflight was in 1961, so 44 years after that was 2005. I think a reasonable conclusion is that manned spaceflight is not on the same curve.
It is not on the same curve if you throw away your rocket after each use (or need months of repairs in case of the Space Shuttle). We would not have commercial transatlantic flights if you would have to throw away the airplane after each flight.Vanadium 50 said:The first manned spaceflight was in 1961, so 44 years after that was 2005. I think a reasonable conclusion is that manned spaceflight is not on the same curve.
With 999,000 people, it is not as isolated, and more comfortable than Antarctica.Vanadium 50 said:Mars will have 999,000 people who have been there for up to fifty years, but it's more isolated and less comfortable than Antarctica.
Biosphere 2 for the isolation in terms of matter, Mars 500 in terms of psychology with a small group and isolation in communication (they artificially added a realistic light-speed delay).gleem said:Does anyone know if there is a project to see how well humans could live without support for two years in a hermetically sealed structure in a hostile environment on Earth with present day technology? Living on a fixed supply food, water and oxygen and seeing how long it would take to develop a sustaining environment. And what about the social issues that can arise? Can a hundred strangers live compatibly in a relatively confined environment and for how long? Would it be like living on a submarine? I hope not.
Solar cells produced on Mars. Probably organic solar cells. They have a poor efficiency, but if you can mass-produce them that is fine. You are not really limited in space on Mars.PeroK said:2) Lightweight power source, small enough to be shipped to Mars. A laptop-sized power station: that would be something!
Which part exactly do you see as unrealistic in the ITS concept?PeroK said:That's why I think having more than a few hardy scientists on Mars, like an Antarctic base, is beyond the foreseeable future.
