Why could we see a laser hologram?
  • Thread starter Thread starter Stanley514
    Hologram Laser
Laser holograms are visible due to scattered light, not the laser beam itself, which is typically too focused to see directly. While lasers can be dangerous if concentrated, when spread out, their power density decreases, making them safer for viewing. Holograms require a medium, such as a screen or material object, to scatter light; they cannot be projected onto thin air as often depicted in sci-fi. Some advanced displays use focused laser pulses to create effects in the air, but these do not qualify as true holograms. Understanding the principles of light scattering and the need for a medium is crucial for comprehending how holograms are viewed.
Stanley514
How could we see a hologram created by lasers if laser beams do not get in our eyes (it could be dangerous)?
Science news on Phys.org
A laser beam isn't worse to the eyes than regular light if it's SUFFICIENTLY spread out.
And regular light that is focused can be just as dangerous as a raw laser beam.
That's correct.However you are missing sth.The laser beam area is about 0.2 cm^2.
In order to see the hologram,you need to splay the beam.In this case the ratio Power/Area is far less than before(The hologram's area could be 4 cm^2 in case of a coin or even bigger).Hope I helped a bit!
you see the scattered light which has much lower power.
I thought that laser hologram is created by pure laser beam in pure air.
Light could be scattered only from some material object?
Holograms can't be projected onto thin air...that's purely sci-fi. You need a screen of some kind, the image then appears in front or behind the screen, but can't go past the edge.
There are a couple 3D displays that either project an image into the air using focused laser pulses to make the air itself glow, or give the effect of projecting onto the air with a spinning screen or mirror, and there's tricks that rely on a smoke or mist as a screen, but these are not holograms.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
