humanist rho
- 92
- 0
In other words why high redshift data is necessary for estimating the acceleration of universe?
You may be confusing Hubble's discovery that the universe was expanding with the much more recent discovery that the rate of expansion is increasing.Drakkith said:Edwin Hubble did discover this.
As the speed of an object away from us increases, relativistic effects cause its light to redshift. From the amount of redshift, we can calculate the object's speed.humanist rho said:In other words why high redshift data is necessary for estimating the acceleration of universe?
Andrew Mason said:You may be confusing Hubble's discovery that the universe was expanding with the much more recent discovery that the rate of expansion is increasing.
AM
Drakkith said:Oh, my mistake. I understand the question now. I'm assuming that it took years of accumulated data to show that the acceleration is increasing?
I think the main reason was improvement in technology. http://www.pnas.org/content/96/8/4224.full" is particularly good in explaining how it was discovered that the expansion rate was increasing (at least that is how the data is being interpreted).Drakkith said:...I'm assuming that it took years of accumulated data to show that the acceleration is increasing?
It's not a matter of analyzing data with better technology. The statistical techniques that one would use to analyze Hubble's data are essentially the same as those that one would use to analyze SN data. The key was pointed out by 2-fish: you need a larger "lever-arm" to get sufficient data and statistics to ascertain that the universe is accelerating. This means going out to much greater distances than Hubble was capable of. Hubble used Cepheid variable stars as standard candles, but these become less accurate indicators of distance the farther out they are. Hubble's data was also adversely affected by the fact that the motion of nearby galaxies are more strongly affected by their peculiar velocities -- local motion that deviates from the cosmological expansion -- than more distant galaxies. No modern-day analysis technique would be able to mollify these sources of error. In fact, while more modern instrumentation might record even more accurate luminosity distances and redshifts than Hubble was capable of, the most important factor is still the distance scale. More recent investigations have considered type Ia supernovae because they are bright and enable an accurate determination to greater distance (the 1998 data of Riess et al spans a distance about 700 times greater than Hubble's data!)humanist rho said:thank u all.
but I've some more questions.
will analysing hubbles data with recent technology give an accelerating universe?
is it possible to have a universe which is accelerating in large redshifts and decelerating at small redshifts?
bapowell said:If the universe were decelerating locally and accelerating more distantly, than this would indicate that we, being at the center of this rather interesting phenomenon, would be something special. The cosmological principle states that there are no such privileged observers -- the universe expands isotropically and homogeneously for *all* observers.
killinchy said:This is my first post, so please be gentle. I am also a Chemist, so please be doubly gentle.
phinds said:I once heard it said that the only use physicists have for chemists is to grab them by the ankles and use them to bash the crap out of an engineer.
I'm an engineer, so I think it's OK for me to pass the story on without meaning any insult.![]()
No. The first indication that the present-day universe was undergoing accelerated expansion came from observations of supernovae redshifts in 1998 by Riess et al:Redbelly98 said:Didn't the acceleration of the universe's expansion come from CMB data taken by the COBE satellite in the 1990's? Hubble died in 1953, before the CMB was even discovered.
Well, technically Redbelly98 is mostly right here, though we actually had to combine the COBE data with other experiments to get a handle on the curvature of the universe from the CMB. Still, at the time, the data was exceptionally noisy, so a lot of people really weren't very confident about it.bapowell said:No. The first indication that the present-day universe was undergoing accelerated expansion came from observations of supernovae redshifts in 1998 by Riess et al:
http://arxiv.org/abs/astro-ph/9805201
and confirmed in 1999 by Perlmutter et al:
http://arxiv.org/abs/astro-ph/9812133
