Why Do Bases Release All Hydroxides Simultaneously?
  • Thread starter Thread starter fire9132
    Base Chemistry
Bases do not release all hydroxides simultaneously; they dissociate in separate steps similar to polyprotic acids. Calcium hydroxide, for example, has two dissociation steps, with the first being very strong and the second having a notable pKb value. The low solubility of calcium hydroxide necessitates consideration of its solubility product (Ksp), which complicates the dissociation process. Experimental evidence shows that solutions contain significant amounts of the CaOH+ complex, indicating an equilibrium between CaOH+ and its dissociated ions. Understanding these dynamics clarifies the behavior of bases in solution.
fire9132
Why do bases lose all of their hydroxides at once?
N/A
Polyprotic acids lose their hydrogen atoms in a step-wise fashion, but bases with multiple hydroxides do not do this. I'm not quiet sure why this occurs, but I think that it's because of the structure of the bases compared to the structure to the acids. If I had Sulfuric Acid and added it to water, it would form bisulfate ions (along with protons). If I had Calcium Hydroxide and added water, it would form Calcium ions and hydroxide ions. Is this because Ca(OH) isn't stable? The bisulfate ions are stable, but Ca(OH) isn't because the Ca essentially has just one valence electron and it would just be better for it to lose the other OH and become Ca2+? I'm not sure. Could someone tell me if my explanation is correct or if I'm completely wrong? Thanks!
They don't, they behave exactly as acids do, with separate dissociation steps and separate dissociation constants. No idea why you think different.
My chemistry teacher asked that question... So I don't know...
Sorry to say that - your teacher is wrong.
Calcium hydroxide has two dissociation steps, typically we assume the first one to go to the end (very strong base), the second one has a commonly listed pKb value of 1.3 (or 1.4). Actually this is a rather complicated system, with low solubility of the base (so you need to take Ksp into account as well), but it is not that difficult to show experimentally that the solution contains substantial amount of CaOH+. That means there exists an equilibrium
CaOH+ <-> Ca2+ + OH-
and it is nothing else but base dissociation (technically indistinguishable from the CaOH+ complex formation).
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
