Why do bottle jacks see differences in air pressure?
Bottle jacks can exhibit slight air pressure differences when the filler plug is removed after pumping. This phenomenon occurs due to the air inside the cylinder warming up during operation, resulting in a pressure slightly higher than atmospheric. When the piston is pushed down, the air is expelled through the filler hole, which can be observed by covering the hole with a thumb or tape. If the filler plug is removed after allowing the jack to cool, no pressure difference will be noticeable as the system returns to equilibrium. Understanding this behavior highlights the hydraulic operation of bottle jacks and the role of air pressure in their functionality.
Jupiter6
131
I've noticed if you remove the filler plug on a typical single-stage bottle jack and pump it up and then push the rod back down you can hear air come out of the filler hole. It's a very slight pressure difference but it's there. You can see this by putting your thumb or a piece of scotch tape over the filler hole.
Is this a result of the air warming up inside the cylinder and creating a pressure slightly higher than atmospheric when you pump it?
Bottle jacks are hydraulic- they operate through displacement of fluid volume. If you open the fill hole (and drain the hydraulic fluid inside) it will instead operate using air, although it won't be able to lift as much weight. When you push the rod back down you're just pushing the air back out.
I'm doing this with all the fluid still in the jack. Jacks are filled with fluid to just under the filler hole.
In other words, if you take a brand new bottle jack that's been properly filled and pump it a few times, then remove the filler plug and push the piston down, you'll see and hear a small amount of air come out of the filler hole.
I suppose if you pump the jack, push the piston down and then remove the filler plug 20 minutes later you won't see any change in air pressure since everything has had a chance to cool down and come back into equilibrium.
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
