Why do I get a Null Pointer Exception when I try to run rewarded ads?
  • Thread starter Thread starter Darkmisc
The discussion revolves around issues encountered while implementing rewarded interstitial ads in an Android application using AdMob. The primary problem is a Null Pointer Exception occurring when attempting to show the ad, specifically due to the `rewardedInterstitialAd` being null. This happens because the ad may not have been loaded successfully before the button is clicked. A suggested solution is to change the method call from `rewardedInterstitialAd.show(MainActivity.this, MainActivity.this);` to `rewardedInterstitialAd.show(this, this);`, as the latter is more appropriate within the context of the class.Further complications arise when users attempt to show multiple ads in succession, leading to crashes. This is attributed to the need for reloading the ad after it has been displayed. It is recommended to implement a method that handles ad loading and ensure that the ad is ready before allowing another display attempt. The conversation highlights the importance of managing ad load states effectively to prevent crashes and ensure a smooth user experience.
Darkmisc
TL;DR Summary
I copied code from the Admob developer page for a rewarded ad and it doesn't work. I get a Null Pointer Exception.
Hi everyone
I've cut and pasted code from here to test rewarded interstitial ads. https://developers.google.com/admob/android/rewarded-interstitial
The only change I've made is to call the ad upon a button click.
When I click the button to call the ad, the program crashes and makes reference to a Null Pointer Exception caused by the following lines:
[CODE lang="java" title="line with error"]rewardedInterstitialAd.show(/* Activity */ MainActivity.this,/*
OnUserEarnedRewardListener */ MainActivity.this);
[/CODE]
Does anyone know why this is happening?
Full code and stacktrace below.
Thanks
[CODE lang="java" title="MainActivity" highlight="62-63"]import static androidx.constraintlayout.helper.widget.MotionEffect.TAG;
import androidx.annotation.NonNull;
import androidx.appcompat.app.AppCompatActivity;
import android.annotation.SuppressLint;
import android.os.Bundle;
import android.util.Log;
import android.view.View;
import android.widget.Button;
import android.widget.TextView;
import com.google.android.gms.ads.AdError;
import com.google.android.gms.ads.AdRequest;
import com.google.android.gms.ads.FullScreenContentCallback;
import com.google.android.gms.ads.LoadAdError;
import com.google.android.gms.ads.MobileAds;
import com.google.android.gms.ads.OnUserEarnedRewardListener;
import com.google.android.gms.ads.initialization.InitializationStatus;
import com.google.android.gms.ads.initialization.OnInitializationCompleteListener;
import com.google.android.gms.ads.rewarded.RewardItem;
import com.google.android.gms.ads.rewardedinterstitial.RewardedInterstitialAd;
import com.google.android.gms.ads.rewardedinterstitial.RewardedInterstitialAdLoadCallback;
public class MainActivity extends AppCompatActivity implements OnUserEarnedRewardListener {
private RewardedInterstitialAd rewardedInterstitialAd;
private String TAG = "MainActivity";
TextView textView;
Button button;
int value;
@Override
public void onUserEarnedReward(@NonNull RewardItem rewardItem) {
Log.i(TAG, "User earned reward.");
value++;
textView.setText(String.valueOf(value));
@SuppressLint("MissingInflatedId")
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
int value =0;
textView = findViewById(R.id.textView);
button = findViewById(R.id.button); MobileAds.initialize(this, new OnInitializationCompleteListener() {
@Override
public void onInitializationComplete(InitializationStatus initializationStatus) {
loadAd();
public void onClick (View view){
**rewardedInterstitialAd.show(/* Activity */ MainActivity.this,/*
OnUserEarnedRewardListener */ MainActivity.this);**
public void loadAd(){
RewardedInterstitialAd.load(MainActivity.this, "ca-app-pub-3940256099942544/5354046379",
new AdRequest.Builder().build(), new RewardedInterstitialAdLoadCallback() {
@Override
public void onAdLoaded(RewardedInterstitialAd ad) {
rewardedInterstitialAd = ad;
rewardedInterstitialAd.setFullScreenContentCallback(new FullScreenContentCallback() {
@Override
public void onAdClicked() {
// Called when a click is recorded for an ad.
Log.d(TAG, "Ad was clicked.");
@Override
public void onAdDismissedFullScreenContent() {
// Called when ad is dismissed.
// Set the ad reference to null so you don't show the ad a second time.
Log.d(TAG, "Ad dismissed fullscreen content.");
rewardedInterstitialAd = null;
@Override
public void onAdFailedToShowFullScreenContent(AdError adError) {
// Called when ad fails to show.
Log.e(TAG, "Ad failed to show fullscreen content.");
@Override
public void onAdImpression() {
// Called when an impression is recorded for an ad.
Log.d(TAG, "Ad recorded an impression.");
@Override
public void onAdShowedFullScreenContent() {
// Called when ad is shown.
Log.d(TAG, "Ad showed fullscreen content.");
@Override
public void onAdFailedToLoad(LoadAdError loadAdError) {
Log.d(TAG, loadAdError.toString());
[/CODE]
Here is the stacktrace.[CODE lang="java" title="stacktrace" highlight="34-35"]E FATAL EXCEPTION: main
Process: com.xxmassdeveloper.rewardedads2, PID: 20217
java.lang.IllegalStateException: Could not execute method for android:onClick
at androidx.appcompat.app.AppCompatViewInflater$DeclaredOnClickListener.onClick(AppCompatViewInflater.java:473)
at android.view.View.performClick(View.java:7870)
at android.widget.TextView.performClick(TextView.java:14970)
at com.google.android.material.button.MaterialButton.performClick(MaterialButton.java:1202)
at android.view.View.performClickInternal(View.java:7839)
at android.view.View.access$3600(View.java:886)
at android.view.View$PerformClick.run(View.java:29363)
at android.os.Handler.handleCallback(Handler.java:883)
at android.os.Handler.dispatchMessage(Handler.java:100)
at android.os.Looper.loop(Looper.java:237)
at android.app.ActivityThread.main(ActivityThread.java:7948)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1075)
Caused by: java.lang.reflect.InvocationTargetException
at androidx.appcompat.app.AppCompatViewInflater$DeclaredOnClickListener.onClick(AppCompatViewInflater.java:468)
**Caused by: java.lang.NullPointerException: Attempt to invoke virtual method 'void com.google.android.gms.ads.rewardedinterstitial.RewardedInterstitialAd.show(android.app.Activity, com.google.android.gms.ads.OnUserEarnedRewardListener)' on a null object reference
at com.xxmassdeveloper.rewardedads2.MainActivity.onClick(MainActivity.java:64)**
2023-02-01 10:30:03.908 20217-20217 Process com.xxmassdeveloper.rewardedads2 I Sending signal. PID: 20217 SIG: 9
---------------------------- PROCESS ENDED (20217) for package com.xxmassdeveloper.rewardedads2 ----------------------------
2023-02-01 10:30:04.207 3675-5653 WindowManager pid-3675 E win=Window{81ddba7 u0 com.xxmassdeveloper.rewardedads2/com.xxmassdeveloper.rewardedads2.MainActivity EXITING} destroySurfaces: appStopped=false win.mWindowRemovalAllowed=true win.mRemoveOnExit=true win.mViewVisibility=0 caller=com.android.server.wm.AppWindowToken.destroySurfaces:1200 com.android.server.wm.AppWindowToken.destroySurfaces:1181 com.android.server.wm.WindowState.onExitAnimationDone:5030 com.android.server.wm.-$$Lambda$01bPtngJg5AqEoOWfW3rWfV7MH4.accept:2 java.util.ArrayList.forEach:1262 com.android.server.wm.AppWindowToken.onAnimationFinished:3549 com.android.server.wm.AppWindowToken.commitVisibility:860
[/CODE]
Technology news on Phys.org
[/CODE]
You were supposed to pass an instance of the Activity class and OnUserEarnedRewardListener interface. Why are you passing MainActivity.this? Just pass this, you are already inside the MainActivity class, which is also an instance of the interface as you have implemented it.
The correct method call would be:
[CODE lang="java" title="Corrected code"]rewardedInterstitialAd.show(this, this);
[/CODE]
Classname.this is a different thing. See https://stackoverflow.com/q/45637427/8387076
Also, your deleted question on Stack Overflow is still popping up in search queries o0)
  • Haha
Likes Darkmisc and jedishrfu
Thanks. It worked, but I can only click on the button once and see an ad. If I try to watch more than one ad in a row, the program crashes (stacktrace below).
If I wait a bit and then try, I can see the ad again, but I can't click the button again without a crash.
Does this have anything to do with load times? I don't understand why the button shouldn't work all the time.
[CODE lang="java" title="stacktrace" highlight="34-35"]FATAL EXCEPTION: main
Process: com.xxmassdeveloper.rewardedads2, PID: 6960
at com.xxmassdeveloper.rewardedads2.MainActivity.onClick(MainActivity.java:65)
2023-02-02 11:45:28.182 6960-6960 Process com.xxmassdeveloper.rewardedads2 I Sending signal. PID: 6960 SIG: 9
---------------------------- PROCESS ENDED (6960) for package com.xxmassdeveloper.rewardedads2 ----------------------------
2023-02-02 11:45:28.304 3675-5805 WindowManager pid-3675 E win=Window{e12d993 u0 com.xxmassdeveloper.rewardedads2/com.xxmassdeveloper.rewardedads2.
[/CODE]
One error I see is that in the full code you posted in the OP, the loadAd() method call at line 58 should be inside the nested class, i.e. between lines 54 and 55.
Note that in the loadAd() method, you are inside a nested class, you have to use MainActivity.this instead of just this, which is what you've already done.
If this change doesn't solve the issue, then I think you have to initialize the ad again once it has been showed (call the nested class callback from line 52 again). Separate this portion out in a method to call easily.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
