I Why Do I Get Electrically Shocked by Metal Objects?
  • I
  • Thread starter Thread starter planck999
    Metal
Electrostatic shocks from touching metal objects, like doorknobs, are more common in colder, drier conditions due to reduced moisture in the air, which allows static electricity to build up. This phenomenon is related to the Seebeck effect, where electrons accumulate on one side, creating a potential difference that causes shocks when contact is made. The shocks result from current electricity rather than static electricity, which remains inactive until a conductive path is established. The drastic temperature changes between indoors and outdoors contribute to charge buildup through friction and induction. Overall, while there are similarities in charge movement, the mechanisms of current transfer differ significantly.
planck999
Whenever I touch to a doorknob or any other metallic object I get electrically shocked. Does this occur because of temperature difference between me and the metal? Is it similar to seebeck effect?
Does this happen to you mainly when it's cold outside?
The air is drier when the temperature is lower because in cold temperatures less moisture can be carried by the air. Which means static electricity cannot discharge that efficiently, hence more electrostatic shocks during winter (or autumn).
Yes it is similar to Seebeck. In each case conditions cause electrons to gather more on one side than the other and when there is a closed loop path, like you touching the doorknob, electrons will flow—the more electrons that flow the more shocking. Some people will say it’s “static electricity” but static electricity doesn’t actually do anything. It just sits there waiting. It is “current electricity” that is shocking. I am told there are numerous explanations of the foregoing from doing a Google search.
Hmm. I would say it’s stretching things a bit to equate motion of charges due to thermal energy and charge separation due to mechanical energy.
The sparks in winter are due to the drastic reduction in the saturation of cold air when it warms up indoors. Those (insulating) conditions allow charges to build up when separated by friction and induction.
Likes nsaspook and tech99
The Seebeck effect can be attributed to two things:
Thermodynamic-chemical potential { electric charge-carrier diffusion and phonon drag.}
- It conducts from DC to a relatively slow response change in thermal difference to each side of different materials.
Electrostatic discharge
Is only caused by triboelectric friction of moving electrons freely liberated to receptor insulators that arc rapidly when the breakdown voltage to differing charge potential exceeds threshold after an ionization time.
It will discharge in pico to microseconds depending on the gap length (door knob to low clouds) and inductance L and charge level whose density lowers the positive ESR resistance while the incremental resistance is negative.
Therefore I see no similarity in current transfer mechanisms.
Likes Greg Bernhardt and sophiecentaur
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
