A Why do novas shine?
A nova occurs in a close binary system where a white dwarf siphons hydrogen from its companion, leading to nuclear fusion on its surface. This fusion generates energy primarily in the form of visible light due to the white dwarf's atmosphere, which acts similarly to a star's photosphere. During a nova event, the photosphere expands dramatically, resulting in a significant increase in luminosity. Bremsstrahlung radiation from the ejected material also contributes to the light observed in novae. Ultimately, the fusion surface remains shielded, allowing the emission of visible light rather than just gamma rays or cosmic rays.
Brzohn
It’s my understanding that a nova happens when you have a close binary star, and one component is a white dwarf. The white dwarf sucks hydrogen from its companion, the hydrogen piles up on the surface of the dwarf until it’s hot and dense enough to undergo nuclear fusion. Ka-boom. Right?
Why is this energy visible light? Nuclear reactions produce energy in the form of gamma rays and moving particles. The reaction is on the surface of the star; the energy isn’t emitted in the middle of an atmosphere that it could be Compton scattered down the spectrum, or heat up the atmosphere till it glows. By my reasoning, a nova should emit gamma and cosmic rays, but not visible light. What’s going on?
Astronomy news on Phys.org
Until just about now I've had the same misconception as you, I think. That the white dwarf is essentially a naked core emitter.
Take a look at this paper:
https://articles.adsabs.harvard.edu/pdf/2012MmSAI..83..779K
There's a brief overview of the process in the introduction.
The key takeaways seem to be:
The nova white dwarf has an atmosphere accreted from its companion. It then emits light from its photosphere, much like a regular star. The photosphere expands significantly during the nova event, on the order of a hundred solar radii, giving rise to the initial luminosity spike. Subsequently, Bremsstrahlung radiation in the ejecta take over as the main contributor to the light curve.
I.e. it doesn't appear to be the case that the fusing surface is ever exposed.
Likes davenn and Drakkith
By the same argument, the sun should not emit visible light either. Does that point you in the right direction?
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
