Why do streamlines converge when water flows down?
Two streamlines cannot converge to a single one, as this would violate the principle of mass conservation, which dictates that streamlines must remain distinct. When water flows from a tap, the cross-sectional area decreases as it falls, leading to an increase in flow speed to maintain constant mass flow, as explained by the Equation of Continuity. Water can start as laminar flow but may transition to turbulent flow depending on factors like flow rate and faucet settings. The closer streamlines during the fall are a result of the need to conserve mass, not due to forces acting on the water. The Equation of Continuity applies to both laminar and turbulent flows, ensuring that mass, energy, and momentum are conserved throughout the flow.
snb
1)Can two streamlines(line of flow) converge to a single one ?
2) When water flows from the tap, as it flows down the horizontal area of cross-section decreases...An argument using the Equation of Continuity is given...but I have two doubts regarding those
i) Is water in freefall Laminar flow ?
ii) Why do streamlines come closer as water goes down ?
snb said:
Can two streamlines(line of flow) converge to a single one?
This would mean that something changed the differening speeds of the two streamlines so they ended up the same. In reality, there's usually a gradual change in speed of flow versus cross section as opposed to infinitely thin shear boundaries between idealized streamlines.
2) When water flows from the tap, as it flows down the horizontal area of cross-section decreases ... Why do streamlines come closer as water goes down?
Mass flow across any cross section of the flow is constant (otherwise mass would be accumulating at some point). As the water falls, it's speed increases while density remains essentually constant, so the cross sectional area decreases.
i) Is water in freefall Laminar flow?
Assuming it starts off laminar from the source, it transitions from laminar flow to turbulent flow as it falls.
No. The definition of streamlines ensures they cannot cross or touch. The physics implied by streamlines crossing would be that you have mass disappearing, so that is the physical intuition that should indicate that it can't happen.
It depends on many factors. Like Randomguy88 said, it can be, It depends on whether it is laminar coming from the source and the flow rate. You can turn on your faucet such that it is laminar the entire way down or turbulent the entire way.
Like Randomguy88 said, the water accelerates, so in order to conserve mass, as the water moves faster, it must have a smaller cross-section to conserve mass flow.
Is Equation of Continuity valid for turbulent flow ?
I wanted to know n explanation in terms of forces or something like that. I am not able to understand why should those streamlines come closer to decrease the cross-sectional area...
Yes, as are the Navier-Stokes equations and energy equation. Regardless of whether the flow is laminar, energy, mass and momentum must still be conserved.
You are out of luck then. It has nothing to do with forces and everything to do with continuity. Think of it this way; you would start out at the top with some v_0 and A_0 and at a given point later in the fall, you would have v_1 and A_1. Now clearly v_1 > v_0 since the water is accelerating. Let's say the area didn't get smaller. The mass flow at the start, \rho v_0 A would be less than at the lower point, \rho v_1 A. Clearly that can't happen because you would be creating mass from nowhere. Going back to continuity, let's use the simplified form:
\rho v_0 A_0 = \rho v_1 A_1
Density is constant, leaving us with
v_0 A_0 = v_1 A_1
Rearranging that, you can get
\frac{v_0}{v_1} = \frac{A_1}{A_0}
Since v_1 > v_0, you also know that \frac{v_0}{v_1} < 1. From our previous equation, that means that \frac{A_1}{A_0} < 1, which leads to the conclusion:
A_0 > A_1
The stream gets smaller.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
