Why do things produce sound even though no pressure is applied to them?
In summary, Sound is a propagating pressure wave in a medium. The pressure wave is generated by any mechanical operation, such as the slipping of rock on a fault line, and creates the sound we hear.
leoneul
I understand that sound is a propagating pressure through a medium. We produced pressure and it’ll propagate through the medium as “sound”. How can we use this model to understand everyday-life experiences like opening a chips packaging and the packaging makes a sound, and alike. In the chips example, where does the pressure even come from so that the sound we hear is produced?
This is just an educated guess:
The crinkly plastic of a chip packet ('crisp packet' to our UK users) is a bit stiff, so that it does not deform smoothly like a piece of soft cloth does. Accordingly, when we bend it with our hands, as we do when opening it. it resists briefly and then gives way in a triggering sort of movement. A triggered movement is much faster than a smooth one, and hence will compress the air it is moving towards much more than a slow gradual movement will. That brief but fast compression creates a high-pitched pressure wave that we hear.
The crinkling sound we hear when somebody is handling a packet of chips is the combination of many pressure waves from lots of little triggerings, as the packet briefly resists and then triggers in many different places.
Likes russ_watters and Drakkith
Not quite ... Sound is a propagating pressure wave in a medium :smile:
It is mechanical wave generated by any mechanical operation, from the slipping of rock on a fault line
causing seismic P waves, to a hammer striking metal, to your vocal cords vibrating to produce sound wavesDave
If any surface moves against a body of air, then there will be a force against the resistance of the surrounding air (i.e. pressure as the air is slightly compressed), locally. In the long term, the air will flow and equalise the pressure. The step increase in pressure will propagate outwards and gradually disperse. The individual small parts of a crisp packet surface will move in small steps which will produce many small pressure peaks (whereas a piece of cloth will tend to flow silently). We hear those peaks as a crackling sound.
Feynman - perhaps not to say in which book - in the second paragraph of chapter 47-2 describe the propagation of sound in a manner described above.
How the strange sound is created can be thought of, but in its own way, every voice is weird.
seriously too complex for a B level thread ... Half of it was even over my head
Related to Why do things produce sound even though no pressure is applied to them?
1. Why do objects produce sound?
Objects produce sound because they vibrate, creating waves of pressure in the surrounding air. These vibrations are then detected by our ears as sound.
2. How do objects vibrate without any pressure applied?
Objects can vibrate due to internal forces or energy, such as thermal energy or electrical energy. These internal forces cause the particles within the object to move, creating vibrations and producing sound.
3. Can objects produce sound in a vacuum?
No, objects cannot produce sound in a vacuum because there is no medium for the sound waves to travel through. Sound waves require a medium, such as air or water, to travel and be detected by our ears.
4. Why do some objects produce louder sounds than others?
The loudness of a sound depends on the amplitude, or strength, of the sound waves. Objects that vibrate with a greater amplitude will produce louder sounds, while objects with smaller amplitudes will produce softer sounds.
5. Do all objects produce sound?
Yes, all objects have the potential to produce sound. However, the sound may not be audible to humans depending on the frequency and amplitude of the vibrations. Some objects, such as a feather, may produce very soft and high frequency sounds that are not detectable by our ears.
  • Mechanics
  • DIY Projects
10K
  • Mechanical Engineering
