Why do trucks have bigger brakes?
  • Thread starter phyzzle
  • Tags
    Brakes
In summary, the brake rotors on a passenger truck like a Chevy 2500 or a Ford F250 are larger than those on a car like a Toyota because the truck needs greater braking force to stop quickly.
  • #36
DaleSpam said:
The first part is correct, but the second part is is not correct. The coefficient of static friction does not change under normal conditions (i.e. good road and tire conditions). Things that cause the coefficient of friction to vary are changes in the surfaces, e.g. ice or water. Applying the brakes does not make ice or water appear to change the coefficient of friction.
Also, it is incorrect to say that the coefficient of static friction is proportional to the force. Remember, the governing equation for static friction is an inequality: fs≤μsfN
Since it is an inequality, it is not correct to say that the force on the left hand side is proportional to the force on the right hand side. Does that make sense?
I was not saying that the force on the left was proportional to the force on the right of the inequality. It is an inequality because the force on the right is the maximum static friction. The actual friction will be an equation and the applied force will be equal to the static friction and directly proportional to the coeffeciant of static friction.
This paragraph from GSU physics department mentions it:
'frictional force is also presumed to be proportional to the coefficient of friction. However, the amount of force required to move an object starting from rest is usually greater than the force required to keep it moving at constant velocity once it is started. Therefore two coefficients of friction are sometimes quoted for a given pair of surfaces - a coefficient of static friction and a coefficent of kinetic friction. The force expression above can be called the standard model of surface friction and is dependent upon several assumptions about friction.'
I will maintain that the coefficient of static friction is not constant. Think if the car is not moving, is there any friction in the horizontal direction?
  • #37
You need to gain a better understanding of constraint forces. Static friction is zero in this case. The coefficient of static friction is not. The coefficient of static friction for a pair of objects yields the maximum of static friction for a given load before the objects start slipping.
  • #38
That paragraph mentions only two coefficients of friction for a given pair of surfaces, a static and a kinetic coefficient. I agree completely. That is the "standard model" of friction.
Under normal braking conditions, as I have been discussing, only the static coefficient applies.
This claim is not correct and is not supported by the reference above nor by your example of a stationary car.
Recall the inequality governing static friction: fs≤μsfN
Typical coefficients of friction on a dry road are 0.7 (ref). A typical car might weigh about 4000 lb. You correctly point out that when the car is not moving the frictional force is 0, so let's plug in these numbers into the inequality.
fs≤μsfN
0 lb ≤ 0.7 4000 lb
0 lb ≤ 2800 lb
true
So, we see that the inequality holds for a stationary car without varying the coefficient of friction. Your example therefore does not demonstrate a varying coefficient of friction.
  • #39
phyzzle, static friction coefficient is a constant. The force of friction is NOT proportional to it, however. Kinetic friction is proportional to kinetic friction coefficient. But for kinetic friction to take over, the wheel must slip, which is not normal braking condition.
Inequality Dale quoted is correct. Friction force is less than or equal to a quantity that is proportional to static friction coefficient. The actual static friction force is a constraint force, and it's magnitude is governed by the constraint itself, and not by any coefficient or magnitude of normal force.
  • #40
Sorry about the above post, I was a little rushed. After looking at the mentioned reference a little closer it was not what I thought it was.
Newton's 3rd law clearly shows that static friction is variable and proportional to the applied force. Because the normal force of the car is constant it must be the coefficient of static friction which is variable. If you push a car in the positive direction with half of the amount of force required to move it, then it will not move.
What is the frictional force at this point? It is not Normal force times the (max)coefficient of static friction. That would be the maximum friction and the actual friction is half of that. The coefficient of static friction does not jump from 0 to maximum. If it did, then when you push the car with half of the force required to move it in the positive direction it would actually move in the negative direction. Of course this never happens. Does anyone see what I am saying?
Check this link: http://www.astro.sunysb.edu/iyers/home/Quiz2_Sol.pdf
  • #41
Doesn't really make sense to call it a coefficient then does it.
As a primary assumption, you can assume that the coefficient of friction is constant, it's why values for it are empirically determined.
As you seem to be having trouble with the basics, load sensitivity will really just screw things up.
The bottom line is:
F=mu_s*N
Defines the operating envelope.
  • #42
D H said:
That is akin to saying that the engine doesn't accelerate the car. That start the wheels rotating. It is friction between tires and road bring the car up to speed.
Which is nonsense. It's putting the cart before the horse.
That friction between tire and road is of course a necessary ingredient in making the car speed up or slow down, but it is the engine and the brakes that are ultimately responsible for making the car change speed.
I share DH's way of viewing it: I prefer to follow the energy. All of the energy to stop the car gets dissipated by the brakes. The tires/wheels are basically just a way of attaching the brakes (and the engine!) to the road.
$.02
  • #43
Thanks for sticking with me on this. I will get it eventually.
  • #44
It's got a bit out of hand though.
I've just skim read the thread since I last posted and you are all going round in circles.
Deal with one thing at once.And thank christ engineers design cars and not physicists.
  • #45
The bottom line is:
F=mu_s*N
Values are not empirically determined, maximum values are determined. And those maximums are very useful.
  • #46
Yes indeed, this thread needed a little humor.
  • #47
I can't tell, are you being serious?
  • #48
Starting from step 1:
The maximum force a tyre can apply longitudinally before slipping (wheel spin) is determined by it's static coefficient of friction. We shall ignore cornering (lateral forces) for this thread.
Ft = Fl * mu_s
Tractive force = load * static coefficient of friction.
Load in this case is defined as gross vehicle weight.
Do you agree with this?
  • #49
You are trying to define FssN. This is NOT TRUE. There is no such equality. Static friction coefficient is NOT the proportionality constant between force of static friction and normal force. That is absolutely NOT how it is defined.
  • #50
how is coefficient of static friction defined? Text book definition would be good so that it can be checked.
My book says (limiting frictional force)/(normal reaction) = coeff of static friction...is my book correct?
  • #51
This is overly nit-picky to the point of being confusing, as it made me go 'huh'?
The equality is how I'd describe it (as I have above), just with the crucial point that it's a maximum value. The force value can be less, which is why it's usually shown as an inequality (you aren't always braking or accelerating at the maximum).
More than getting to, and arguing about definitions. I feel the crucial thing to take away is that the the equation above is the maximum 'potential' force that can be applied by a Tyre-surface system. It is always likely to be less.
Operating envelope for Tyre, or GG diagram. As force is proportional to acceleration, the graph would look the same for force.
http://hpwizard.com/gg-diagram.html
  • #52
Yes, your book is correct. Key word here is "limiting". It's the maximum amount of friction force you can have. The actual force of static friction is whatever it needs to be up to that limiting force.
Trouble is, phyzzle isn't talking about the maximum force. He's talking about whatever the force of friction is, and he insists that static friction coefficient changes to match it, which is simply not how it is defined. It's not nitpicking. It's pointing out the actual flaw in logic that sends phyzzle along a completely wrong route.
  • #53
Awesome, I agree with your post completely. And I think we are seeing eye to eye.
In your statement;
'I feel the crucial thing to take away is that the the equation above is the maximum 'potential' force that can be applied by a Tyre-surface system. It is always likely to be less.'
Can I rephrase it as saying that the force that can be applied by a Tyre-surface system is variable? Since you said it has a maximum but is always likely to be less? Variable?
And if so, since there are 2 factors that determine the friction of a tyre-surface system one being normal force or weight of vehicle which we know is constant, then the other factor has to be variable. Yes?
The other factor is of course the coefficient.
  • #54
Friction force divided by normal force is a nonsensical quantity. It has no physical meaning. It's not a coefficient of anything.
  • #55
Newton's 3rd shows that the friction of the tire on the road is equal and opposite to the friction of the road on the tire. I don't know if you are calling one of those the "applied force" or if you are referring to some other force. If you mean one of the friction forces then it is not just proportional, it is equal and opposite, which is a much stronger statement. If you mean some other force then that is not true in general.
Why? There is only one equation that I know of which involves the coefficient of static friction and it allows for a range of forces for a constant coefficient. Are you aware of any formula other than fs≤μsfN which uses μs? If so, please post it with a reference.
Agreed, but this fact does not support your argument. See my above rebuttal, and simply substitute 1400 lb on the left hand side where I had 0 lb, the same process refutes this argument as your previous one.
Yes, I see exactly what you are saying, but you are simply wrong.
  • #57
In symbols, your book says
fs max/fN = μs
which can be rearranged to
fs max = μs fN
and since
fs ≤ fs max
we have
fs ≤ μs fN
in which, as both K^2 and I have pointed out, μs is not a coefficient of proportionality.
  • #58
fs max/fN = μs
fs max = μs fN
and since
fs ≤ fs max
we have
fs ≤ μs fN
Dalespam, I have resolved my initial question thanks.
If an object is being pushed without moving, the opposing frictional force is equal and opposite to that force pushing on the object. Increase the force a little bit without moving the object and the opposing frictional force will increase to match it. The normal force has not changed, so what has changed to cause an increase in the opposing frictional force?
Did you check out this link? Please take a look.
  • #59
Excellent, although it seems like you still have a misunderstanding about the meaning of the inequality in the static friction force equation.
Nothing. Remember that the equation is an inequality:
fs ≤ μs fN
So nothing has to change. Specifically, a change in fs does not in any way imply that there must have been a change in either μs or fN.
Do you understand what ≤ means? Do you see the difference in form between that and the equation for kinetic friction: fk = μk fN
Yes, I did.
  • #60
Push against a wall. It pushes back with the same force. Push harder. It pushes back harder. What changed? Certainly not a friction coefficient of any kind, since no friction is involved.
  • #61
K^2 said:
truesearch, you need to brush up on constraint forces. If you insist that brakes aren't stopping the car, which is technically correct, then you need to realize that the force applied to wheels doesn't stop the car, either. It stops the wheels. You say, no friction, no stopping. I say, wheels not attached to car, no stopping. It's the same idea, really.
I can understand why one would wind resistance and the contact forces between tire and road to be special -- they are the only external forces in the picture. Brake pad on rotor, axle on bearings, those are all internal forces to the car. All important in ensuring braking happens correctly, of course, but they are the car acting on itself.
(and, of course, what is internal and what is external changes if we separate the car into parts)
  • #62
It's an important enough distinction that it trips people up when learning about friction, as it has here. Teachers frame questions designed to flesh-out whether students grasp the difference. If you provide a student with a block sitting on an incline and a coefficient of friction, then ask to find the force of friction, you'll find out if they know the difference...
  • #63
fs ≤ μs fN
Yes, I did.
Okay, I finally get it. Sorry it seems pretty obvious to me now. I hadn't been thinking about the inequality, I was thinking about it conceptually and illogically so. I think I will go post this same question on the monster truck forum. I am sure I will get some equally astute responses.
  • #64
Yes I am aware of another formual which uses μs. In Tipler's college physics text, 3rd edition, chapter 5 he has an inequality for the static friction force and an equation for fs max. At least I think that is what your asking, at this point I honestly am not sure of anything.
Anyhow thanks again for your help, I appreciate your patience while schooling me.
  • #65
In case you're interested here is the link for the formula. It will put you on page 73, just scroll up to page 71.
http://books.google.com/books?id=XF...QLG0ZXrBw&ved=0CEwQ6AEwAQ#v=onepage&q&f=false
  • #66
But that formula doesn't apply since you are explicitly considering forces less than fs max.
  • #67
In theory why can't the forces be equal to fs max? The forces would still be that of static friction as opposed to kinetic friction right?
  • #68
The forces can be equal to fs_max. They don't have to be though.
EDIT: This is unless I've misunderstood what's going on. It's starting to become difficult to follow what is being discussed.
You seem to be having trouble with this, so just ignore the theory for now, and go with a graphic representation.
F=mu_s*N.
This gives that maximum force available to the tyre whilst rolling.
Draw a circle with that radius. If you are asking the tyre to apply a force that lies in the circle you are fine, if you are out of it you are knackered.
  • #69
Try this: a 1kg block is placed on a 45 degree inclined plane. The static friction coefficient is 0.5. Does it slide?
  • #70
That doesn't make sense from what we have been discussing. If the car is at rest then the force is 0 as you have correctly pointed out multiple times. It cannot be both 0 and the maximum.
In order for the force to be at f max you would have to be braking as hard as possible using ideal antilock brakes.
