Why do we use a gradient in centrifugation?
  • Thread starter Thread starter red65
In centrifugation, a homogeneous solution of cesium chloride (CsCl) is used to create a density gradient when subjected to high centrifugal forces, around 100,000 g. This gradient forms naturally as the different density components of a mixture become buoyant at various locations within the centrifuge tube. The process relies on the interplay of gravitational forces and intermolecular interactions. While CsCl is denser than water and would normally sink, the significant gravitational force during centrifugation enables the separation of CsCl from water based on density, allowing for effective separation of molecules in the mixture. This gradient is crucial for isolating components with varying densities, enhancing the efficiency of the centrifugation process.
red65
Why do we use a gradient of ions(Caesium chloride )in centrifugation, I expect if we add in a test tube the molecule that we want to know its density and a gradient of caesium chloride, that the caesium chloride will accumulate in the region that corresponds to its density so as our molecule what is the purpose of this gradient ???
Biology news on Phys.org
We don’t put in a gradient of CsCl; we put in a homogeneous solution of CsCl and subject it to ~100 000 g, and the gradient forms naturally. This happens to be convenient for us if we want to separate a mixture based on density, as the different density components of the mixture are buoyant at different locations in the centrifuge tube.
Likes jim mcnamara, Hornbein, pinball1970 and 1 other person
why would a gradient form, shouldn't all molecules of CsCl assume the location corresponding to their density, and why would it be more convenient to have a gradient in centrifugation?
Why don’t all molecules of CsCl assume the location corresponding to their density even before you centrifuge the mixture? CsCl is far more dense than water; shouldn’t all the CsCl sink to the bottom? What else do you think could be going on?
you previously said "We put in a homogeneous solution of CsCl" , which suggests that the concentration of CsCl is the same anywhere in the solution, well if CsCl is way denser than water, you can continuously mix the solution so that it stays homogeneous
The point I’m trying to nudge you towards is that if gravity were the only force acting on the molecules, then yes, all the CsCl would immediately sink to the bottom of the vessel, regardless of how weak that gravity is. However, gravity is not the only force at work. Intermolecular and ionic forces, along with thermal fluctuations, are orders of magnitude larger than the gravitational force at 1g. However, at ~100 000 g, the gravitational force is strong enough to begin separating the CsCl from the water by density, at least a little bit. This is what gives you the gradient in density gradient ultracentrifugation.
Likes berkeman, red65 and jim mcnamara
I've been reading a bunch of articles in this month's Scientific American on Alzheimer's and ran across this article in a web feed that I subscribe to. The SA articles that I've read so far have touched on issues with the blood-brain barrier but this appears to be a novel approach to the problem - fix the exit ramp and the brain clears out the plaques. https://www.sciencealert.com/new-alzheimers-treatment-clears-plaques-from-brains-of-mice-within-hours The original paper: Rapid amyloid-β...
https://www.discovermagazine.com/the-deadliest-spider-in-the-world-ends-lives-in-hours-but-its-venom-may-inspire-medical-miracles-48107 https://en.wikipedia.org/wiki/Versutoxin#Mechanism_behind_Neurotoxic_Properties https://www.sciencedirect.com/science/article/abs/pii/S0028390817301557 (subscription or purchase requred) The structure of versutoxin (δ-atracotoxin-Hv1) provides insights into the binding of site 3 neurotoxins to the voltage-gated sodium channel...
