Why does [1H2O->1(H) + 1(OH)], yet [10^(-14)M=10^(-7)M+10^(-7)M]?
  • Thread starter Thread starter LearninDaMath
The discussion centers on the confusion regarding the ionization of water and the relationship between concentrations of hydrogen ions and hydroxide ions. The original poster questions why the equation 10^{-14}M(H2O) = 10^{-7}M(H^{+}) + 10^{-7}M(OH^{-}) holds true, while their analogy involving physical objects suggests otherwise. They compare this to the fusion of marbles, arguing that the concentration should not require addition if substances combine. A response clarifies that the correct understanding involves the equilibrium constant K_w, which defines the relationship between the concentrations of H^+ and OH^-. The thread concludes with a reminder to adhere to established equations in chemical discussions.
LearninDaMath
Say I have 10(H2O) that ionizes into H and OH. The reaction would be
10(H2O)→10(H) +10(OH)
Because if you have 10 of something, and then then split it into 2 pieces, you have 10 of each piece.
If I have 1 piece of paper and I tear it into 2 pieces, I have 1 piece in my right hand and 1 piece in my left hand. It makes sense.
The reactions is
1 full paper → 1 torn piece + 1 torn piece.
So just like 1 torn piece of paper + 1 torn piece of paper ≠ 2 full pieces of paper,
10(H)+10(OH) ≠ 20(H2O).
But how the the heck is this following equation true:
10^{-14}M(H2O) = 10^{-7}M(H^{+})+10^{-7}M(OH^{-})
Why is it not:
10^{-7}M(H2O) = 10^{-7}M(H^{+})+10^{-7}M(OH^{-})?
I wonder if this question makes any sense or not?
If I have 10 blue marbles and drop them into a Liter of water, the concentration will be 10 blue marbles/1L
If I have 10 red marbles and drop them into a liter of water, the concentration will be 10 red marbles/1L
With 10 blue marbles + 10 red marbles dropped into a Liter of water, I will obviously have 20 separate marbles/1L
But if each red and blue marble fused into a purple marble, I'd end up with 10 purple marbles/1L.
What I'm saying is, the concentration of marbles/Liters stays the same. There is no reason to do any addition if the marbles are fusing into purple marbles.
So why is there addition when speaking on this reaction:
How is concentration so different than quantity, that in one instance 1A+1B→1(AB), yet for another instance, 1M(A)+1M(B) → 2M(AB)
Please don't start separate threads when the problem is already discussed elsewhere.
You started with an incorrect premise. No idea where you got it from. Correct equation is
K_w = [H^+][OH^-] = 10^{-14}
https://www.physicsforums.com/showthread.php?p=4105295#post4105295
Topic locked.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
