Why Does a Gyroscope's Spin Axis Maintain Its Direction?
The spin axis of a gyroscope maintains its direction due to the conservation of angular momentum, which states that in the absence of torque, angular momentum remains constant. This principle is analogous to Newton's second law for linear momentum. The angular momentum vector, which is derived from the cross product of the radius and momentum, points in the direction of the spin axis. Consequently, without external forces acting on it, the gyroscope will continue to spin at a constant speed and direction. Thus, the spin axis remains stable unless influenced by external torques.
powerball
In GPB's experimental conditions, a negligible amount of precession takes place.
So in terms of rotational inertia, why does the spin axis of a gyroscopes remain pointing in the same direction?
Also, why would changes in space-time cause the axis to change?
Thanks
Actually i understand the second part, just not the rotational inertia bit
Because of the conservation of angular momentum. In absence of a torque the angular momentum of the gyroscope is conserved. This is basically the rotational analog of Newtons second law for conservation of 'normal momentum' in absence of a force.
The angular momentum, which is a vector, points in the direction of the spin axis, because it is the crossproduct of the radius and momentum of the gyroscope. In absence of a torque the gyroscope will spin with a constant speed AND direction. So the spin axis of the gyroscope will remain pointing in the same direction.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
