Why does a plasma ball emit light?
In summary, a plasma ball emits light due to the ionization of gas within the globe. When high-voltage electricity is applied to a central electrode, it creates an electric field that ionizes the surrounding gas, forming plasma. This plasma consists of charged particles that emit light as they collide and recombine. The colors observed in the plasma ball are a result of different gases used inside and the energy levels of the excited particles.
ahmeds
TL;DR Summary
Plasma ball ligting
Is the cause of the lighting due to the impact of electrons with the nucleus
Can you explain why plasma ball emit light……….its long article in wiki i do not understand
Likes Delta2
The basic idea is that a high voltage produces and accelerates ions. Those ions collide with neutral gas molecules which becomes excited. When the excited gas molecule relaxes to the ground state, the energy from being excited is released as light.
Likes davenn, sophiecentaur, Delta2 and 1 other person
No, not the nucleus.
To put it in non-physical language ...
The electric field in the plasma ball, tears electrons away from the outside surface of the gas atoms, leaving empty holes. The light is emitted when electrons fall back into those holes. The colour of the light is determined by the element and the depth of the hole.
Likes Hornbein, Astronuc, vanhees71 and 2 others
Imo that's a bit sweeping. If there are ionised Hydrogen atoms about, there 'could' be an interaction with a proton (H+ ion / nucleus).
To be fair, though, the Lyman Series of spectral lines, which are due to electron / proton transitions are of invisible, very short wavelengths.
Visible lines tend to be produced from interaction with ions, other than Hydrogen, that are only partly ionised.
This is not about any hydrogen ions that might be about.
To quote Wikipedia, the sphere is; "filled with noble gases, usually a mixture of neon, krypton, and xenon".
We are discussing a real toy / cheap demo with a mixture of gases. It would be unlikely that the contents of the globe would be of high purity. The law of diminishing returns applies and this gadget has to sell at a reasonable price. The contents would be of similar purity to common or garden balloon gas. (Not so easy to come by these days.)
But my problem was with your categorical "no" about electrons hitting a nucleus. The "no" is a sweeping statement and could be mis-leading. That's all.
That is correct. The gas mix is unimportant, so long as it works. Any UV emitted will not be "seen" directly, but may increase the ionisation of the plasma, which may then emit visible light.
This was a beginners question, so I went for understanding the basic principle. The "impact of electrons with the nucleus", needed to be clearly eliminated, before understanding the quantum physics of visible light.
Likes hutchphd
Yes but a 'sufficient' answer would not usually be a minimalist answer. A beginner would surely need to have it pointed out that only one electron would be missing from an atom. That would mean that the collision would involve interaction with the nucleus and the rest of the electrons. It costs nothing to expand on the word "no", particularly when helping a beginner. We know that a recombining electron goes nowhere near the nucleus.
No.
YES.
  • Haha
Likes hutchphd, berkeman and sophiecentaur
FAQ: Why does a plasma ball emit light?
A plasma ball emits light due to the ionization of gases inside the sphere. When a high voltage is applied, it ionizes the gases, causing electrons to become excited and then release energy in the form of light as they return to their ground state.
What gases are used in a plasma ball?
Plasma balls typically contain a mixture of noble gases such as neon, argon, and xenon. These gases are chosen because they ionize easily and emit bright, colorful light when electrically excited.
How does the high voltage create plasma inside the ball?
The high voltage applied to the central electrode in the plasma ball creates an electric field that strips electrons from the gas atoms, forming ions. This process generates a plasma, which is a state of matter consisting of free electrons and ions.
Why do the light filaments in a plasma ball move when you touch the surface?
When you touch the surface of a plasma ball, you provide a path to ground for the electric current. This alters the electric field inside the ball, causing the plasma filaments to be attracted to your touch and move toward it.
Is the light emitted by a plasma ball harmful?
The light emitted by a plasma ball is generally not harmful. It is primarily visible light, with some ultraviolet light, but the levels are low and not dangerous. However, it is still advisable to avoid prolonged exposure and not to touch the plasma ball for extended periods.
