Why does a rubber band's tension grow when stretched?
In summary, the tension in a rubber band is caused by the electric bonds between its particles. When the rubber band is stretched, the particles are pulled apart, causing the electric force to diminish and the tension to shrink. However, tension actually increases when the rubber band is stretched due to the long chains of polymer molecules that act like springs when stretched. These chains are held together by cross links and have kinetic energy that keeps them bunched up. When the rubber band is extended, the cross link points move apart and the chains act like springs, causing tension to grow.
sillycow
My very beginner level understanding is that the rubber band's tension stems from it's particles being held together by it's electric bonds: Atoms and molecules are bound together by their electric charges.
And so, When I stretch a rubber band, I am presumably pulling it's particles away from each other: Same amount of atoms/molecules are distributed over a longer space. The electric force diminishes as charges are pulled further apart from each other, so I would expect the tension to also shrink.
Then why does tension grow when the rubber band is stretched?
Rubber is made up of very long chains of polymer molecules that are attached to each other at various locations called "cross links." In between the cross links, the polymer chains are not straight. They are very bunched up, and much shorter than their extended length. The segments of the chains have kinetic energy which keeps them bunched up. When you extend the rubber, what you are doing is stretching the chains (moving their cross link points apart), and, because of the kinetic energy of the segments, the chains act like little springs. This is what causes the tension when you stretch the rubber.
Likes vanhees71, davenn, sillycow and 1 other person
Related to Why does a rubber band's tension grow when stretched?
1. Why does a rubber band stretch when pulled?
Rubber bands are made of long chains of molecules called polymers. When a rubber band is stretched, these polymer chains are pulled apart, causing the rubber band to lengthen.
2. How does a rubber band's tension increase when stretched?
As the rubber band is stretched, the polymer chains are pulled closer together, causing them to become more tightly packed. This increase in molecular density leads to a higher tension in the rubber band.
3. Why does a rubber band return to its original shape after being stretched?
When the tension on a rubber band is released, the polymer chains are able to relax and return to their original, more randomly arranged state. This allows the rubber band to return to its original shape.
4. Can a rubber band be stretched too far?
Yes, a rubber band can be stretched to the point where the polymer chains break, causing the rubber band to lose its elasticity and become permanently stretched out.
5. How does temperature affect a rubber band's tension?
Temperature can affect a rubber band's tension in two ways. First, at higher temperatures, the polymer chains are more mobile and can stretch more easily, resulting in a lower tension. Second, extreme temperatures can cause the rubber band to become brittle and break more easily.
  • Classical Physics
  • DIY Projects
  • Other Physics Topics
