Why Does an Egg Break Differently on Grass Versus Sidewalk?
An egg dropped on grass typically does not break due to a greater time interval for stopping compared to when it hits a sidewalk. The discussion revolves around the physics of momentum and collisions, suggesting that the change in momentum is less on grass. The participant initially considers option "E," indicating a lesser change in velocity, but ultimately questions if this is correct. Newton's second law is referenced to analyze the forces involved, emphasizing the relationship between force, mass, and acceleration. The conclusion points to the importance of the stopping time in determining whether the egg breaks.
jer_hall99
A moderate force will break an egg. However, an egg dropped on the road or sidewalk usually breaks, while one dropped on the grass usually does not break. This difference is because for the egg dropped on the grass:
A. the change in momentum is greater
B. the change in momentum is less
C. the time interval for stopping is greater
D. the time interval for stopping is less
E. the change in velocity is less
vf=(m1v1+m2v2)/(m1+m2)
My thoughts are that the answer is "E" because the change in velocity is less because when the egg comes in contact with the grass, a perfectly inelastic collision occurs where if the egg hits the sidewalk, it is only an inelastic equation.
Are my thoughts right, or is it a different answer?
What does Newton's 2nd law say?
The acceleration a of an object is directly proportional to the net force acting on it and inversely proportional to its mass. That doesn't help me too much... Maybe I'm not putting two and two together. Is the answer "E" then?
Newton's 2nd law: 'the rate of change of momentum is directly proportional to the applied force and takes place in the direction of this force'.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
