B Why does an inductor discharge?
  • B
  • Thread starter Thread starter versine
    Discharge Inductor
An inductor discharges when connected to a capacitor due to the relationship between current and magnetic fields. When current flows through the inductor, it creates a magnetic field, storing energy as described by E = ½·L·i². Upon connecting to a capacitor, the inductor begins to transfer energy, charging the capacitor while the inductor current decreases. This process creates an oscillation of energy between the inductor and capacitor, described by harmonic motion equations. The interaction continues until the energy is fully exchanged, illustrating the dynamic behavior of inductors and capacitors in an electrical circuit.
versine
A capacitor will discharge because once a path is created there is a potential difference $V=Q/C$. But for an inductor it's $L\frac{di}{dt}$. Why would an inductor want to discharge once you connect it to a capacitor?
If there was no current flowing through the inductor, then there is no energy stored, and no magnetic field.
E = ½·L·i² ;
If a current is flowing through the inductor when it is connected to a zero volt capacitor, the current will begin to charge the capacitor.
Q = I·t ; v = Q / C ; E = ½·C·v² ;
As the capacitor voltage increases, the inductor voltage will also increase, that will reduce the inductor current, until it stops, reverses, and repeats, circulating the energy between L and C.
v = L·di/dt ;
Likes tech99 and versine
Just write down the equation from Kirchhoff's rule:
$$L \dot{i}+Q/C=0$$
Since ##i=\dot{Q}## this means
$$L \ddot{Q}+Q/C=0$$
The general solution of this "harmonic-oscillator equation of motion" is
$$Q(t)=A \cos(\omega t) + B \sin(\omega t) \quad \text{with} \quad \omega=\sqrt{\frac{1}{LC}}$$
and
$$i(t)=-A\omega \sin(\omega t) + B \omega \cos(\omega t).$$
For ##Q(0)=Q_0## and ##i(0)=0##, i.e., having some charge on the capacitor and then at ##t=0## connect it to the coil, then you get ##A=Q_0## and ##B=0##. So the final solution reads
$$Q(t)=Q_0 \cos(\omega t), \quad i(t)=-Q_0 \omega \sin(\omega t).$$
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
