Why does an inverse exist only for surjective functions?
A function must be surjective for its inverse to exist because the inverse is defined only on the range of the function. If a function is not onto, there will be elements in the codomain that do not correspond to any element in the domain, making it impossible to define an inverse for those elements. For example, the exponential function is one-to-one and has an inverse (the natural logarithm), but it only maps to positive values, limiting the inverse's domain. Additionally, if the range is a subset of the codomain, there may be values in the codomain without a corresponding input, complicating the definition of the inverse. Therefore, a function must be surjective to ensure a well-defined inverse exists.
kay
In other words, why does a function have to be onto (or surjective, i.e. Range=Codomain) for its inverse to exist?
Mathematics news on Phys.org
The key property for a function to have an inverse is that it is 1-1. Any 1-1 function will have an inverse. The inverse, however, can only be defined on the range of the function. Perhaps this is best explained by an example:
The exponential function ##e^x## maps the real number line ##(-\infty, \infty)## onto ##(0, \infty)##. The exponential is 1-1, so there exists an inverse (the natural logarithm). But, the inverse is only defined on ##(0, \infty)##. You can't define the inverse function on all of the real number line.
This raises perhaps a technical point that if you are considering the set of functions that map ##\mathbb{R}## to ##\mathbb{R}## then the exponential function is in this set, but there is no inverse within this set of functions. From that point of view, the inverse doesn't exist.
Likes kay
Actually my question was, that why can't an inverse exist for a function whose range is not necessarily equal to but is rather a subset of the codomain.
An inverse of a function f: A \to B is a function g: B \to A such that g(f(a)) = a for all a \in A and f(g(b)) = b for all b \in B. An inverse is unique if it exists.
Let f: \{1,2\} \to \{1,2,3\} : x \mapsto x. Now the inverse of f, if it exists, is a function g: \{1,2,3\} \to \{1,2\}. Now we must have g(1) = 1 and g(2) = 2, but what value do you assign to g(3) such that f(g(3)) = 3?
Likes kay
I got it. Thanks a lot for your help. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
