Why Does Fullwave Bridge Rectification Raise Voltage by 1.41?
  • Thread starter Thread starter rytmenpinne
    Bridge Voltage
Fullwave bridge rectification increases voltage by a factor of 1.41 due to the relationship between RMS voltage and peak voltage, where V_peak equals √2 times V_rms. The secondary ratings on transformers are specified in RMS, not peak voltage. Additionally, a bridge rectifier causes the output voltage to drop by approximately 1.4 volts due to the current passing through two diodes. Understanding these principles clarifies the behavior of voltage in rectification processes. This knowledge is essential for accurate electrical engineering applications.
rytmenpinne
..fullwave bridge rectification raise the voltage *1.41? I scanned the net but I can't find an explanation as to why, only that it does..
Remember, ac voltage is really regarding RMS voltage, and hence,
\sqrt{2}V_{rms}=V_p
where
\sqrt{2}=1.41...
Aah, so basicly what's going on here is that the secondary ratings on transformers is given in RMS? and not peak?
That's correct. Also note that a bridge rectifier will have the current passing through two diodes, so the output voltage will be 1.4 volts less than the peak.
Good! thank you both! the world now makes sense again
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
