Why does graphene tend to break during mechanical exfoliation?
  • Thread starter Thread starter wayneyie1986
    Graphene Material
Graphene produced through tape exfoliation often breaks into fragments due to forces that induce fracture, primarily influenced by grain boundary failure and stress from bending. While single-crystalline graphene is strong and typically resistant to breaking, the presence of grain boundaries in few-layer graphene makes it more susceptible to fracture under tensile and compressive stresses. Additionally, surface cleanliness at the atomic level plays a significant role in adhesion, which can further contribute to fragmentation. Relevant literature suggests that these factors are critical in understanding the limitations of tape exfoliation methods. Overall, the mechanical properties and structural integrity of graphene are significantly affected by these physical phenomena.
wayneyie1986
Is there any specific physical reason that can explain why graphene produced by tape exfoliation tends to break into fragments instead of remaining as a original size perfect piece? Some of the literature I found only briefly mentions that it's due to certain forces causing graphene to fracture, resulting in the production of small pieces. If possible, providing references to relevant literature would be appreciated. Thanks for the assistance.
Likes wayneyie1986 and Lord Jestocost
Single-crystalline graphene should not break even if it bended, owing to its high strength. The most likely cause for observed fracture would be grain boundary failure. For few-layer graphene, any possible fracture could be attributed to bending induced tensile stress at one side and compression stress on the opposite side. Still, if they are in single crystal form, it would be rather hard forthem to break either.
I need to anneal 5052 aluminum for a home project. Google has given me mixed results on how to do this. Short version is that I'm doing some heavy forming on a piece of 5052-H32 and I'm running into issues with it work hardening. I've tried the Sharpie trick with a propane torch. But I'm not sure this is doing anything. I'm also seeing conflicting opinions whether to quench or air cool. So I'm looking for some expert opinions. (Oven heating is not an option due to size.) Thanks. edit: The...
  • · Replies 28 ·
  • · Replies 21 ·
  • · Replies 62 ·
11K
