Why does ice have no friction?
  • Thread starter Thread starter sameeralord
    Friction Ice
Ice does not have no friction; it has relatively low friction due to the melting that occurs at the interface when weight is applied. As an object slides on ice, the pressure causes a thin layer of water to form, reducing friction and allowing for smoother movement. This phenomenon is often misunderstood, as there is still some friction present, which prevents indefinite sliding. The melting point of ice can be slightly lowered by the weight of a person, contributing to the formation of this water film. Understanding these dynamics is crucial for activities like skiing and skating, where efficient movement relies on this thin layer of water.
sameeralord
If you come in contact with any object, it is not going to resist your movement right, why doesn't ice do this much. What chemical property is responsible for this?When I slide in ice, am I coming into less contact with ice, I don't understand. Thanks :smile:
when you slide on ice, you push with your weight. So it melts at the interface (ice and you). Therefore you slide. (sliding on thin layer of water..)
be careful when you say "why does ice have no friction" this is misleading compared to what you are asking since Ice doesn't have no friction but relatively little as you have identified.
like rajini has said, ice melts as you slide against it.
take into consideration the water formed as ice melts, it would decrease the friction between the ice and the object.
there would still be friction between ice and an object or you would be able to slide indefinitly
This is a common myth. The weight of a guy of 70 kg would cause a decrease of the melting point of ice which is on the order of 0.2 degrees. For skiing, sledging, and skating, friction causes a water film to build up which allows efficient skating. Apart from that a small water film of only a few nanometres thickness is always present due to pressure-independent surface effects.
See for example:
S. C. Colbeck, "Pressure melting and ice skating", American Journal of Physics, October 1995, Volume 63, Issue 10, pp. 888-890
for details.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
