Why does length contraction solve this? (2 Lightclocks)
In summary: But if two events are spatially separated, then observers in different frames would see them as happening at different moments. This is called the relativity of simultaneity. It is the single most challenging concept to learn.
kablion
Hey,
I'm currently working on an explanation of the special Relativity. Now I'm at the point of explaining length contraction, but I don't understand why the following example is a reason for length contraction to exist:
Imagine we have two Lightclocks in a fast moving Rocket. Lightclock 1 points in the direction of movement and lightclock 2 is perpendicular to that.
In the inertial frame of the rocket both lichtclocks run synchronously. But from another inertial frame they would run asynchronously, because the way, that the light in lightclock 1 has to travel is longer than the way in lightclock 2. That can't be, because the lightclock has to run synchronously. So one thinks of the length contraction as solution.
But the lightclock 2 has two lightways with the same lenght, whereas lightclock has one longer way, when the light has to travel in the same direction as the rocket. That means through length contraction, the total way is equal, but it still runs asynchronously because the time both lightclocks need to complete one of the to ways isn't equal. So why is length contraction the solution to this, althought it only solves the total distance.
To make it more visible to you I've found a video, that shows my problem. The only thing: It's german. But the things that are said don't matter if you read my post:
I hope you understand what I mean and can help me.
Kablion
This doesn't make sense. If the total distance (which is what I assume you mean by "way") the light has to travel is the same, and the speed of the light is the same, then the time it takes the light to travel must be the same.
Ok I guess you didn't understand me right.
The total way the light has to travel is divided in two ways (I think you know what a lightclock is?!): the way the light has to travel from the first mirror to the second mirror and the light has to travel back again to the first mirror.
So the lightclock, which points in the direction of movement, has a longer first way than the second way.
But the lightclock which is perpendicular has both ways with the same length.
So due to length contraction the total length (way1 + way2) of both lightclocks is equal,
but the lengths of the way1 of both lightclocks is not equal (same to way2)
Ok way easier to understand is the question:
At the end of the Video after the length contraction happens, all photons arrive at the sun at the same moment,
but the photons arrive at the outer circle at different moments. Why does this difference of the arrival time not matter? For the observer in this inertial frame all photons arrive at the same moment on the outer circle.
I think this problem isn't solved with length contraction.
They arrive at the same time in the rest frame; but not at the same time in the moving frame, because they are spatially separated along the line of motion.
@kablion it's only the total distance which matters, total time is the total distance divided by c and it is the same for both clocks.
By the way, that video is slightly wrong at 2:49 and 2:52, the four pulses would not arrive at the inner circle simultaneously in the shuttle frame.
Ok I think I understand now what my real problem here is:
Why or How can 2 events occur at the same moment in one frame, but in another frame they occur at different moments?
Has this scenario or theory a name?
Yes. This is the relativity of simultaneity. It is the single most challenging concept to learn.
All frames agree if two co-located events occur at the same time, but for events that are spatially separated, different frames will disagree about whether or not they are simultaneous.
Likes Chestermiller
That video is misleading because the light source is of significant size. You really need to redo the problem with a point source of negligible size.
Note that if events are simultaneous at the same point in space in one frame, they must be simultaneous and at the same point in space in another frame.
But if events are simultaneous and at different points in one frame, then they will not in general be simultaneous in another frame.
In the video this happens noticeably when the light rays going left and right get reflected. In the moving frame these events are simultaneous: Both rays get reflected at the same time. But, in the rest frame, the ray on the left gets reflected before the ray on the right gets reflected. In the rest frame these are not, therefore, simultaneous events.
This is true. So what? A "tick" of the clock is a round trip; the fact that the two legs of the round trip have unequal lengths for one of the light clocks is irrelevant, as long as the round trip time is the same for both, which it is.
Ok to all of you: You helped me a lot! Thank You!
That relativity of simultaneity was the one thing I missed on understanding special Relativity.
FAQ: Why does length contraction solve this? (2 Lightclocks)
Why is length contraction necessary to solve the problem of 2 light clocks?
Length contraction is necessary to solve the problem of 2 light clocks because it is a fundamental concept in the theory of relativity. Without taking into account length contraction, the measurements and observations made in the context of 2 light clocks would not align with the principles of relativity.
How does length contraction solve the problem of 2 light clocks?
Length contraction solves the problem of 2 light clocks by adjusting the perceived length of an object based on its relative velocity. This means that as an object moves faster, its length in the direction of motion appears shorter to an observer. By taking into account length contraction, we can accurately measure and compare the observations made in the context of 2 light clocks.
Can you provide an example of how length contraction solves the problem of 2 light clocks?
Imagine two observers, one stationary and one moving at a high velocity, both measuring the length of a moving object using 2 light clocks. To the stationary observer, the object appears longer due to the effects of length contraction. However, to the moving observer, the object appears shorter because of its relative velocity. By accounting for length contraction, both observers can make accurate measurements and reconcile their differing observations.
Why is it important to consider length contraction in the context of 2 light clocks?
Considering length contraction in the context of 2 light clocks is important because it allows us to accurately measure and compare observations made by different observers in different frames of reference. Without taking into account length contraction, there would be discrepancies and inconsistencies in our measurements, making it difficult to understand and explain phenomena in the context of relativity.
Is length contraction the only solution to the problem of 2 light clocks?
No, length contraction is not the only solution to the problem of 2 light clocks. Other concepts such as time dilation and the relativity of simultaneity also play a role in understanding and solving this problem. However, length contraction is a fundamental aspect of relativity that is necessary to accurately measure and compare observations in the context of 2 light clocks.
