B Why does light diffraction create circular patterns?
The circular shape of light observed under trees is due to sunlight passing through gaps in the leaves, acting as pin-hole lenses that project images of the solar disk. This phenomenon does not produce visible diffraction patterns in daylight but results in circular projections because the sun is a circular object. During an eclipse, these projections can appear as crescents, further illustrating the pin-hole effect. The size of the projected image varies with the distance from the aperture, prompting inquiries about formulas for calculating this size. Understanding this optical behavior enhances the appreciation of natural light patterns.
abrahamabraham
TL;DR Summary
We see under trees circular light that goes from sun through the leaves gaps. Why does it create a circular shape and not other shapes? why does this diffraction phenomenon create it in circular patterns?
Can you upload a couple pictures of what you are seeing? Use the "Attach files" link below the Edit window to upload a PDF or JPEG image.
The diffraction pattern will depend on the size and shape of the aperture. See the Wikipedia article for a good introduction to diffraction:
https://en.wikipedia.org/wiki/Diffraction
Likes Lord Jestocost
In daylight conditions, sunlight passing through gaps in the leaf cover will not produce readily visible diffraction patterns.
But those gaps will act as pin-hole "lens"s. So in the shadow of the canape you will see projected images of the solar disk - which is circular.
Likes russ_watters, nasu, Gleb1964 and 1 other person
I can attest to this because during an eclipse the circles turn into crescents. You are seeing a projected image of the face of the sun. There is an eclipse here on 8 april ......I will report
Likes russ_watters and dlgoff
I was living in Virginia during the 1984 annular eclipse. Hence ring-shaped shadows. Although we had clear skies, atmospheric effects combined with the annular shape to create some really weird lighting effects.
Yes, this is exactly what I observe. Also, the size of the image varies with the distance from the aperture. Is there a formula for calculating the the size of the expected image for a given distance?
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
