Why does liquid co2 goes back to solid at atmospheric press
Liquid CO2 transitions directly to solid at atmospheric pressure due to the unique properties of its phase diagram. When pressure drops from 5.11 atm to 1 atm, the temperature also decreases, which contributes to the solidification process. This phenomenon occurs because the rapid pressure drop allows some CO2 to evaporate, cooling the remaining liquid and facilitating the formation of solid CO2. The phase behavior indicates that under certain conditions, the liquid can bypass the gaseous state and revert to solid. Therefore, the solid state reforming from liquid CO2 at 1 atm is primarily a result of both pressure and temperature changes during the experiment.
vlajky
I you look at the phase diagram, CO2 is in liquid state at 5,11 atm and t= -56 C. But why does he convert directly to solid state at 1 atm? Again, if you go down from five to one atm, you should be in gaseous state ? Is it have something to do with temperature ? What happens with temperature during the pressure drop?
I am specifically asking about liquid to solid transition that occur in the experiment explained below and why it happens during the pressure drop. On phase diagram if pressure drop from 5 to 1 atm at t= -56,6 c you are in the gaseous state? It must be the temperature drop all so ? If it is, why it happens ?
experiment :
Dry ice is placed into an PET plastic cylinder. A valve is closed and pressure in the cylinder increases. When the pressure reaches 511 kPa it stops increasing and liquid CO2 appears. The liquid begins to boil and when all solid CO2 is gone, the pressure increases further. The valve is opened and the pressure drops again to 1 atm. Eventually solid CO2 reforms, the liquid disappears? WHY THE SOLID STATE REFORMS AGAIN ( from liquid ) RATHER THEN GASEOUS ?
Without knowing the details I can hazard a guess. With the pressure drop some of the CO2 evaporates cooling the rest which becomes solid.
I think you're right. That's the only reasonable explanation. Thank you!:)
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
