fog37
- 1,569
- 108
- TL;DR Summary
- understand why one of my devices periodically disconnects from the home wifi network
Hello,
I have a wifi device that has been connecting with no issues to my local wifi: it first detected the local wifi and I then used the password to complete the connection....
However, one day recently, the device disconnected from the wifi. After some reading, it seems that either low wifi signal or interference could cause a device to disconnect...But my device is always located in the same place and does not move. So if the wifi signal power was good in the past, it should continue to be good and sufficient in the present...Also, interference would not seem to be the issue since there aren't any other devices connected to wifi in the same room or other rooms....
What other cause could lead to my device to randomly disconnect from the wifi and then struggle to refind the SSID?
thank you!
thank you!
