Why Does My DSC Baseline Go Below Zero?
  • Thread starter Thread starter jaejoon89
    Zero
The discussion centers on the issue of a Differential Scanning Calorimeter (DSC) displaying baseline values below zero (negative values). Key points include the possibility of bad calibration affecting the readings, as the absolute number is less significant than the relative change from the initial value set. Another consideration is the potential conversion between polymorphs, which could release energy and result in negative values. Participants also suggest verifying the consistency of results by running the same sample multiple times to see if the negative values persist.
jaejoon89
My baseline for the DSC goes past zero (below 0 W/g) why would the instrument be doing this?
Chemistry news on Phys.org
This may be obvious, but: Bad calibration?
it goes relative to the initial value you put in. the absolute number does not mean much.
Perhaps you converted from one polymorph to another and a little energy was released? Have you run the same sample twice and noticed the negative value again?
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
