Why does someone with normal vision not need glasses?
  • Thread starter Thread starter Xelb
    Optics
Individuals with normal vision do not require glasses because their eyes are properly shaped, allowing light to focus directly on the retina without additional lenses. Far-sighted individuals need glasses with a positive focal length to help converge light rays, enabling them to see nearby objects clearly. Conversely, near-sighted individuals require glasses with a negative focal length to diverge light rays, allowing them to focus on distant objects. The discussion emphasizes the importance of understanding the basic principles of optics to grasp these concepts. Overall, clarity on these topics is essential for those studying vision and corrective lenses.
Xelb
These are more-so explanation based and there is no math involved.
1) How come someone with "normal vision" does not require glasses?
2) Why does a far sighted person require glasses with a positive focal length?
3) Why does a near sighted person require glasses with a negative focal length?
It's bad enough that we have not covered the chapters dealing with optics in lecture yet, so some brief clarification would be greatly appreciated. Thank you!
Welcome to the PF.
We require that you show some effort in answering these schoolwork questions before we can offer much tutorial help. That means that if you have not covered this in your coursework yet, you should use the web or your textbook to do some reading about the basics involved. Then you should be able to take at least a afirst cut at answering the questions, and we can check your answers for you.
I did a Google search on Corrective Lenses Conceptual Questions, and this was one of the first hits (Google suggested the last two words of the search):
http://www.angelfire.com/scifi2/eyeglass/
That should help you out...
So I was able to figure out the answers to questions 2 and 3.
For 1, however, I'm still not sure about it...but here's my guess:
Because a normal eye is neither elongated nor smaller, this means that neither a converging or diverging lens is needed in order to focus nearby objects on the retinal surface. On a normal eye, the image is produced normally on the retina because the refraction process begins when light reaches the eye.
Sounds reasonable to me. :smile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
