Why Does the Gödel Universe Rotate?
The Godel metric describes a rotating universe, which can be analyzed by observing the behavior of a gyroscope in Godel coordinates. An observer stationary in this metric experiences precession if the universe is indeed rotating, prompting the need to calculate the rate of precession. The equations of motion derived from the metric indicate that the spin of the gyroscope is subject to parallel transport, leading to specific relationships between its components. The discussion highlights confusion around relating the spin vector to the precession velocity and the angular momentum, with the expectation that the result should yield a specific angular velocity. Clarifications on the equations of motion and transformations to a locally flat frame may be necessary to resolve the uncertainties.
GRDoer
Consider the Godel Metric in spherical coordinates as on page 6 here;
ds^2=4a^2\left[-dt^2+dr^2+dz^2-(\sinh^{4}(r)-\sinh^{2}(r))d\phi^2+2\sqrt{2}\sinh^{2}(r)dt d\phi)\right]
This is a solution to Einstein's Equations if we have ##a=\frac{1}{2\sqrt{2\pi\rho}}## and ##\Lambda =-\frac{1}{2a^2}##, where ##\Lambda## is the cosmological constant and ##\rho## is the density of the uniform dust with which we fill the universe.
It is often stated that this represents a rotating universe, but to me that is not immediately obvious, and so I want to prove it. To do so I'm considering an observer stationary with respect to the Godel coordinates at some point ##(r,\phi,z)## and equipped with a gyroscope. If the universe is rotating, the gyroscope should obviously precess. I want to find the rate of precession.
Einstein's Equations and those mentioned throughout the post.
The observer is stationary, so we have ##-1=\vec{u}\cdot\vec{u}=g_{\alpha\beta}u^{\alpha}u^{\beta}=g_{tt}(u^{t})^{2}=-4a^{2}(u^{t})^{2}##, so ##u^{t}=\frac{1}{\sqrt{2}a}## and so ##\vec{u}=(\frac{1}{\sqrt{2}a},0,0,0)##.
##a## is constant so clearly ##\vec{a}=0##, so the gyroscope is in free fall. This means its spin, ##\tilde{S}## undergoes parallel transport; ##\nabla_{\vec{u}}\tilde{S}=0##. Spin is a 1-form so we have:
\frac{S_{\alpha}}{dt}=\Gamma^{\gamma}_{\alpha\beta}S_{\gamma}u^{\beta}u
This means that ##s_{z}## and ##s_{t}## are constant, and as we must have ##\tilde{S}\cdot\vec{u}=0##, ##s_{t}=0##.
The resulting ODES are;
\frac{dS_{r}}{dt}=\frac{\sqrt{2}}{a\sinh(2r)}S_{\phi}
\frac{dS_{\phi}}{dt}=-\frac{1}{2\sqrt{2}a}\sinh(2r)S_{r}
They have general solution:
S_{r}(t)=-2i(A\exp({\frac{it}{a\sqrt{2}}})-B\exp({-\frac{it}{a\sqrt{2}}}))
S_{\phi}(t)=\sinh(2r)(A\exp({\frac{it}{a\sqrt{2}}})+B\exp({-\frac{it}{a\sqrt{2}}}))
I'm not sure how to go from here to the angular velocity/momentum associated with the spin.
The spin 1-form is given component wise by ##s_{\alpha}=\frac{1}{2}\epsilon_{\alpha\beta\gamma\delta}J^{\beta\gamma}u^{\delta}##, which let's us use the above result to find the components of ##J^{\alpha\beta}##, and I believe I should find something along the lines of ##\frac{dS}{dt}=\Omega\times S## for some angular velocity ##\Omega##, but classical mechanics never was my strong suit so I'm not sure of the specifics. Honestly the whole concept of spin and precession in GR is doing my head in.
I think the result should be ##2\sqrt{\pi\rho}##, which I have seen while researching online, but yeah, I have no idea how to prove it.
I guess the crux of my question is how do we relate ##S_{\alpha}## to the precession velocity of the gyroscope of which it is the spin?
Any pointers, general or specific would really help, thanks.​
I just noticed a few typos in the above. Throughout the t's should be ##\tau##'s, theyre the proper time of the observer. Also ##u^{t}=\frac{1}{2a}## not ##\frac{1}{\sqrt{2}a}##. I already made one edit, and apparently I can't make more so I'll post this here.
Also, if I try to evaluate ##\Omega\times S## for an arbitrary angular velocity ##\Omega## and equate this to ##\frac{ds_{i}}{d\tau}##, where ##i\in\{1,2,3\}##, I get
(\frac{2}{a\sqrt{2}\sinh(2r)}S_{\phi}(\tau),\frac{-\sinh(2r)}{2\sqrt{2}a}S_{r}(\tau),0)=(-\Omega_{z}S_{\phi},\Omega_{z}S_{r},\Omega_{r}S_{\phi}-\Omega_{\phi}S_{r})
Which due to the ##\sinh(2r)## factor cannot be true for a general position.
I don't know where I'm going wrong. Maybe I've solved the equations of motion wrong somehow, maybe I'm misunderstanding precession, or maybe I need to transform the result to the locally flat frame of the observer (which I have no idea how to do), or something else entirely.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
