Why does the magnetic field/flux change in copper conductor?
In summary: The copper coil experiences a changing magnetic field when the magnet is dropped through it, which induces an emf. The moving electrons in response to the emf create a current. The magnet must be in motion for the emf to be induced in the copper coil. This is why a copper tube is not necessary, as long as there is a changing magnetic field, an emf will be induced. In summary, when a permanent magnet is dropped through a copper tube, it creates a changing magnetic field which induces an emf in the copper. The moving electrons in the copper create a current in response to the emf. The magnet must be in motion for the emf to be induced, and a copper coil is sufficient for this to occur.
CAH
48
If you drop a permanent magnet like steel through a copper tube it induces an emf, this is because you have a change in magnetic field/flux? But how? Why? The copper isn't producing a current before the magnet is dropped into it... Does something happen with the electrons in the copper?
The electrons are present in the copper before you drop the magnet, but there is no emf, so they don't move. After you drop the magnet the changing B-field induces an emf in the copper, and the electrons move in response to the emf. The moving electrons are a current. Does this answer your question?
So do the electrons in the copper get attracted/repulsed by the magnet causing them to move? And when you say changing B field do you mean it goes from zero (in the copper) to experiancing the magnetic field of the steel? Yes I think so. Thank you
You don't need a copper tube. A copper coil is enough. It is not that the electrons are attracted/repulsed by the magnetic field. In fact. If you hold the magnet and the coil still without moving either of them, there is no emf, even though there is a magnetic field. It is only when you drop the magnet, while the magnet is in motion, the flux through the coil changes, and the changing flux causes the emf.
Related to Why does the magnetic field/flux change in copper conductor?
1. Why does a magnetic field form around a copper conductor?
A magnetic field forms around a copper conductor due to the movement of electrons within the conductor. As electric current flows through the copper, the electrons move in a specific direction, creating a circular magnetic field around the conductor.
2. How does a change in current affect the magnetic field in a copper conductor?
A change in current in a copper conductor will cause a change in the strength of the magnetic field. An increase in current will result in a stronger magnetic field, while a decrease in current will result in a weaker magnetic field.
3. Why does the magnetic field direction change when the current direction changes in a copper conductor?
The direction of the magnetic field around a copper conductor is determined by the direction of the current. When the current changes direction, the magnetic field also changes direction to remain perpendicular to the current flow.
4. How does the length of a copper conductor affect its magnetic field?
The length of a copper conductor does not have a significant impact on the strength of its magnetic field. However, a longer conductor will have a larger surface area for the magnetic field to form around, resulting in a slightly stronger field compared to a shorter conductor.
5. Why does the magnetic flux change in a copper conductor?
The magnetic flux, or the amount of magnetic field passing through a given area, changes in a copper conductor due to changes in the strength of the magnetic field. This can occur when there is a change in current, or when the conductor is moved in relation to a magnet.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
