jbriggs444
2024 Award
- 13,413
- 8,079
Explanations involving torque of the wheel or the tension in the chain should not be thought of as competing explanations. They are simply different ways of looking at the same physical situation.Dr. Headholio said:I think the wheelie can be simply explained through these 2 horizontal forces (at the contact patch and at the center of mass). However, some explanations I have seen also consider the torque of the engine on the rear wheel, and an opposing torque that lifts the front end as has also been posted in this thread here
Whether the chain tension is an "internal" or an "external" force depends on where you draw imaginary lines around the system of interest. If you concentrate on the rigidly connected bicycle frame, engine and rider then the rear wheel is not part of the system. (And if you concentrate on the rear wheel, the bicycle frame, engine and rider are not part of the system). Either way chain tension is an external force.In my thinking this [chain tension as an explanation] is not true. The torque on the engine creates chain tension which turns the rear wheel. This chain tension is a horizontal force between the rear wheel sprocket and the engine sprocket. It is an internal force and creates no torque about the COM.
But chain tension is not the only external force. If all you had was chain tension, the rear wheel would be drawn forward to the engine. That does not happen because the rear wheel is mounted on an axle that is attached to the frame. So you also have frame compression which amounts to a second external force between wheel and frame/engine/rider. Taken together, these two forces are a "couple" -- a pair of equal and opposite forces that amount to a pure torque.
