Why does the wave of color that has a greater index of refraction bend more?
The discussion centers on the behavior of light as it passes through a prism, specifically regarding how different colors bend based on their indices of refraction. It clarifies that while a higher index of refraction leads to a smaller angle of refraction, the overall change in angle is greater for colors with higher indices, such as blue. This is due to the relationship defined by Snell's law, which indicates that the bending occurs twice—once entering and once exiting the prism. Ultimately, blue light, having the highest index of refraction, deviates more from its original path compared to red light. Understanding this principle is crucial for grasping how prisms separate colors in white light.
101nancyma
Hi guys, I just have a short question. A prism splits white light into it component color depending on the wavelength of the color. As the wavelength decreases, the index of refraction increases, so the wave bends more. However according to Snell's law, a greater index of refraction results in smaller degree of bend of the light. So why does the wave of color that has a greater index of refraction bend more?
thanks so much
Science news on Phys.org
keep in mind the light gets bent twice, once when entering the prism, and once when leaving the prism. The second is where most of the bending takes place.
Thanks a lot for the response. Blue has a greater index refraction than red, so should red bend more the second time than blue if snell's law holds true?
Good.
Good.
You are misunderstanding Snell's law, which says n1sinθ1 = n2sinθ2. It's true that as the index of refraction (n2) increases, the angle of refraction (θ2) decreases. But that leads to a greater change in angle, which is what counts. (If θ1 = θ2, that would mean the light didn't bend at all.)
So blue, which has the greatest index of refraction, deviates from its original path the most; red, the least.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
Thread 'How to model converging illumination through object plane (in ZEMAX)'
Hello community, I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging...
