Why Earth has constant acceleration?
In summary, the Earth exerts a non-constant force on an object during free fall due to the changing distance between the two objects. However, for practical purposes and near the surface of the Earth, the acceleration of objects in free fall is constant at 9.81 m/s^2, which is a good approximation due to the small changes in distance involved.
Akshaydave14
according to f=GMm/r^2 if force changes based on a distance between 2 objects, so during free fall object is constantly changing its distance, so does that mean the Earth is exerting a non-constant force on that object? if that was right, why's that object accelerate at a constant rate of a=9.81?
does changing force in F=ma also change acceleration? and why the Earth has a constant acceleration rather than changing?
Yes, it varies slightly as ##r## changes.
They don't. 9.81 is not exact. It is a very good approximation near the surface of the earth, so we use it when we're solving problems near the surface of the earth. To get a sense of just how good an approximation it is, try calculating the difference between the the force when ##r## is equal to 6371 km (the average radius of the earth) and when ##r## is equal to 6371.1 km (100 meters higher up).
Likes Akshaydave14
You are completely correct, the force varies with r, so the "constant" acceleration is just an approximation.
To see why that approximation works consider what it would take to get a 1% error in the force. Since the force is proportional to 1/r^2 you would need about a 0.5% change in r of about 20 miles. So for throwing a baseball or shooting a gun it is approximately constant, but for launching a rocket you need to account for the changing force.
Likes Akshaydave14
FAQ: Why Earth has constant acceleration?
Why does Earth have constant acceleration?
Earth has constant acceleration due to the force of gravity acting on all objects. This force causes objects to accelerate towards the center of the Earth at a constant rate of 9.8 meters per second squared.
How does gravity affect Earth's constant acceleration?
Gravity is the force that causes objects to accelerate towards the center of the Earth. This means that all objects on Earth experience the same acceleration due to gravity, resulting in a constant acceleration.
Is Earth's constant acceleration the same everywhere on the planet?
Yes, Earth's constant acceleration due to gravity is the same everywhere on the planet. This is because gravity is a fundamental force that acts uniformly on all objects, regardless of their location on Earth.
How does Earth's constant acceleration affect objects on its surface?
Earth's constant acceleration affects objects on its surface by causing them to fall towards the ground at a rate of 9.8 meters per second squared. This is why objects dropped from the same height will hit the ground at the same time, regardless of their mass.
Can Earth's constant acceleration change over time?
No, Earth's constant acceleration due to gravity does not change over time. This is because gravity is a fundamental force that remains constant. However, the perceived acceleration of objects may change due to factors such as air resistance or changes in the Earth's mass distribution.
