Why include a 1/2 factor in the drag equation?
  • Thread starter Thread starter damosuz
    Drag
The inclusion of the 1/2 factor in the drag equation F_{R} = \frac{1}{2}\rho C_{d}A v^{2} is essential because it aligns with the definition of dynamic pressure, which is expressed as \rho v^2/2. Omitting this factor would disrupt the scaling relationship with dynamic pressure, leading to incorrect calculations if one were to simply halve the C_d values from tables. The factor ensures that aerodynamic coefficients, such as C_L = \frac{L}{qS}, fit neatly within the framework of flight mechanics. This convenience is particularly beneficial for applications in stability and control. Therefore, the 1/2 factor is crucial for accurate aerodynamic modeling.
damosuz
Why the 1/2 factor in the equation F_{R} = \frac{1}{2}\rho C_{d}A v^{2}? Why not just divide every C_{d} value found in tables by 2 and omit the 1/2 in the equation instead?
The only reason I can think of is that the guy proposing this formula was thinking the force should be proportional to half of one of those things in it(I don't know why though!) and he wants to get sure people have a clue for that. I think the best candidate is the area.
Energy of compressed spring is ##\frac{1}{2}kx^2##. So according to you I will do some magic and replace all k value of spring in every table to k/2.
Now I have an equation ##F=kx##. This is the force exerted by a compressed /elongated spring. If I use the values given in the new table, I will get wrong answer. So I will have to multiply 2 every time I use it. Maybe ##C_d## has other uses and ##C_d## is more commonly used than ##C_d/2##.
In the sense of this equation, the drag scales with dynamic pressure, which is defined as ##\rho v^2/2##. The ##1/2## therefore comes from the fact that the equation contains the dynamic pressure. Without that factor, you could still just divide ##C_d## by two but the scaling with dynamic pressure would be wrong.
Likes FactChecker and Redoctober
Pretty much like boneh3ad said. Having the 1/2 makes the Aerodynamic coefficient wrap up in a nice manner ## C_L = \frac{L}{qS} ## with the dynamic pressure.
It's really convenient this way especially when it comes to application in Flight mechanics, Stability and Control.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
