Why is a Big Back Advantageous for Delivering Mechanical Power?
  • Thread starter Username34
  • Tags
    Strength
In summary, a big back is advantageous for delivering mechanical power due to its ability to provide greater strength and stability. The increased muscle mass and leverage from a larger back enhance force generation during physical activities, enabling individuals to lift heavier loads and perform more strenuous tasks effectively. Additionally, a strong back supports proper posture and reduces the risk of injury, promoting sustained power output over time.
Username34
29
It is said that individuals with large back/spinal structure have a distinct advantage at delivering power, all else equal.
My question is why in concrete terms this is advantegous if the weight and speed of another individuals is similiar?
Has a person with larger back stronger support to push through the target, so that he can deliver more mass into the target?
Or is it related to generating kinetic energy?
Welcome to PF.
It may have been said, but where has it been written?
Is this about boxing, or also about walking up hills?
Likes pinball1970 and BillTre
Baluncore said:
Welcome to PF.
Quora section on mechanical power in martial arts. I can't find the post. What is your first intuitive reaction to why a larger back gives an advantage in delivering mechanical power? Is it momentum or strength related? Can an average back not utilize as much strength in the joints? Or can they not generate as much momentum in the action?
Why wouldn't an average sized back be able to torque as much?
To me it seems more strength related (the pushing action of the mechanical delivery).
The stronger your back is, the more support you have behind the "pull" or "push" into the target.
But that's just my guess.
Your legs contact the floor. Your arms apply the force. The line between your hips must be coupled to the line between your shoulders. What connects them if it is not your back and your stomach muscles in tension, with your spine in compression.
Likes russ_watters
But why is the exact structure of those muscles relevant to delivering power?
Username34 said:
You are not hitting the target with the weight of the back, it's the weight of the arm or leg
But to accelerate your arm, you must put your back into it.
Likes nuuskur and pinball1970
Most wrestlers have wide backs, so it's clearly related to strength.
But is it strength in terms of delivering mass or delivering energy, or both?
Neither.
You are delivering momentum, the product of mass and velocity.
Wrestlers don't punch/push, they pull. Different (opposite) set of muscles.
They push when shooting for a takedown.
Baluncore said:
Neither.
Why can't an average back do that just as well?
So what? Speaking as a former wrestler (and a pretty good one), most of the strength moves are pulling moves, as Russ suggests.
Likes russ_watters
Exactly where it is said? In what context?
What I know is about the muscles around the whole torso keeping together/producing the base (mass) for movement, not only the back.
If you can accelerate more mass to a greater velocity, you can deliver more momentum to the opposition, then watch them retire, while you stand there.
No, they don't. They pull their opponent's legs toward them. The "shoot" is just reaching to grab the legs - no strength involved.
-Also a pretty good wrestler.
Likes Mondayman and berkeman
This means nothing without pictures. :smile:
(digging through my old yearbooks...)
Likes pinball1970 and russ_watters
Ow, my arm! You're twisting it! Stahp! Ok, fine, here it is:
I'm the one in front. Yes, I won. This was one of two times I made the paper, and my mom bought and framed the print. In fairness though, I was engaging my left pect in this photo, not my back.
[edit]
On second thought, I was pulling my left arm forward, but also pushing back up into my opponent with my legs, which would engage my back muscles as well.
  • Wow
Likes pinball1970 and berkeman
The push is coming from their legs, independent of back/arms. I was into boxing, and I got dropped on my head by good wrestlers more than once.
Yes, that's true, the wrestler is pushing himself forwards and hopefully through the opponent with his legs. But my interpretation of the OP was that it was referring to upper body pushes/punches. These are very different motions. Rereading, the OP is far from clear, other than focusing on the back.
Broadly speaking this sounds like a sports biomechanics question - and, in an also broad sense - it is just a matter of applying laws of mechanics to a body seen as a system of joints, levers and effectors.
So, start with a good understanding of the Newton mechanics (part of training of any physicist or mechanical engineer), draw the schematics of the body with long bones as levers and joints as rotation points (basic anatomy), see what kind of forces/moments you are looking for, see how to get them from the system and how to optimize the system to make them higher. You will find that you need a stronger effector here, a longer lever there - just translate these into the overall frame.
Likes russ_watters and Bystander
[edit]
That's a great picture!
Likes russ_watters
Read all the replies, all relevant and I will add this.
If you have a skinny back, you may have a skinny something else.
Train all of your body parts, you cannot ring fence your lats for instance without training your arms when you are doing chins.
You cannot train your legs doing squats without involving your back.
You cannot train your chest doing bench press with out training your front delts, triceps, forearms and hands!
Ask the gym instructor, get the right diet and you will get stronger and bigger all over, not just your lats.
A lot of the strength in wrestling involves lifting and twisting your torso by pushing on the floor with hands and feet. The upper body leverage is facilitated by broad shoulders. I was a very bad wrestler in high school and understand too well the physics of "sitting out" as an escape move. Also "bridging" to avoid the pin......
FAQ: Why is a Big Back Advantageous for Delivering Mechanical Power?
Why does a larger back help in delivering more mechanical power?
A larger back typically means more muscle mass, which can generate greater force. This increased muscle mass allows for more powerful movements and better support for lifting and carrying heavy objects, thereby enhancing mechanical power output.
How does a strong back contribute to overall stability and balance?
A strong back provides a solid foundation for the rest of the body, improving overall stability and balance. This is crucial for performing tasks that require precise and powerful movements, as it minimizes the risk of injury and enhances efficiency.
What role do back muscles play in protecting the spine during heavy lifting?
Back muscles play a critical role in stabilizing and protecting the spine. Strong back muscles help maintain proper posture and alignment, reducing the strain on the spinal column and intervertebral discs during heavy lifting, thus preventing injuries.
How does back strength correlate with endurance in physical activities?
Back strength is closely linked to endurance, as stronger muscles can sustain prolonged physical activity without fatigue. This is particularly important in activities that require repetitive or sustained exertion, allowing for better performance over longer periods.
Can a strong back improve performance in sports and physical activities?
Yes, a strong back can significantly enhance performance in various sports and physical activities. It contributes to better posture, more powerful movements, and increased resistance to fatigue and injury, all of which are essential for high-level athletic performance.
