Why is an Attitude Indicator not Built Like a Ball Compass?
  • Thread starter Thread starter greypilgrim
Attitude indicators in airplanes utilize complex gyroscopic systems rather than simple bottom-heavy spheres to accurately reflect the aircraft's orientation. This design is crucial because during maneuvers like banking turns, the weight vector of a sphere would mislead pilots due to the altered perception of "down." Basic attitude indicators, commonly found in general aviation aircraft, use a single gyro and are powered by vacuum systems, while more advanced models allow for greater motion and are often electric. The most sophisticated units, which provide comprehensive pitch, yaw, and roll data, rely on aircraft navigation computers rather than gyroscopes. Overall, the evolution of attitude indicators reflects the need for precision and reliability in flight instrumentation.
greypilgrim
Hi.
I used to think that the attitude indicators (artificial horizons) in airplanes were just bottom-heavy spheres swimming in a liquid in a transparent shell, like a ball compass:
But apparently they use quite a complicated gyroscopic system. Why?
Likes berkeman, Flyboy, jack action and 1 other person
Right. Of course.
In a banking turn, "down" is no longer down.
Likes sophiecentaur and russ_watters
Bit late to the party, but there’s a couple different types of attitude indicators you might cross paths with.
The most basic one, such as is found in Cessna 172s and other general aviation airplanes, uses a single gyro to simply display the local horizon within a limited pitch and bank angle range. They are typically powered by a vacuum pump on the engine or a venturi on the exterior of the airplane on particularly old models. They’re simple, inexpensive, and reasonably accurate for normal flight, but can be damaged if you perform spin training while they’re operating. Needless to say, flight school mechanics get quite grumpy when an instructor does not warn/inform the shop that spin training will be taking place. Typical the gyro vacuum line will just be disconnected and an inline filter installed to protect the vacuum pump, and the system tagged “INOP” and logged as such until after spin training and the system is restored.
More advanced units will still have only one gyro, but will be electric and have much more range of motion, allowing for a complete 360° roll and 180° pitch display. These are typically used as backup units on modern jets, although standalone digital units are increasingly widespread.
The most advanced units, which display pitch, yaw, and roll information alongside a compass bearing, are, to my knowledge, not gyroscopic in nature and are instead driven by the aircraft’s navigation computer. These were quite common from the 1960s until the advent of the “glass cockpit”, but have largely been phased out of service due to the complexity of the mechanisms used and the versatility of primary flight displays and multi-function displays that make up a “glass cockpit”.
Likes Lnewqban and berkeman
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
15K
