MHB Why Is Cosine Used to Calculate Angle Y in a Right Triangle?
  • Thread starter Thread starter ai93
    Cos Triangle
Cosine is used to calculate angle Y in a right triangle because it relates the length of the adjacent side to the hypotenuse, expressed as cos(Y) = adjacent/hypotenuse. In triangle XYZ, with XY as the hypotenuse (15 mm) and YZ as the adjacent side (8 mm), the calculation yields Y = arccos(8/15), resulting in approximately 57.8 degrees. The Pythagorean theorem is then applied to find the length of side XZ, confirming that XZ^2 + YZ^2 = XY^2. This reinforces the understanding that in right triangles, both cosine and the Pythagorean theorem are essential for solving for angles and side lengths. The discussion highlights the importance of SOHCAHTOA in trigonometric calculations.
ai93
Hi, this would be my first post of many in recent times as I have my maths exam soon! I am doing a lot of past papers and I need some help understand some questions.
In the triangle $$XYZ$$ angle $$Z$$ is a right angle. If $$XY$$= 15mm and $$YZ$$=8mm, calculate the angle $$Y$$, giving your answer in degrees accurate to 1dp.
The solution was;
$$COSY=\frac{8}{15}$$
$$\therefore Y=COS^{-1}\frac{8}{15}$$
=$$Y=57.8$$
Can someone clarify why COS was used, and how to attempt similar questions like this?
Continuing from this question,
Calculate the length of the side $$XZ$$
I see pythag theorem was used as the solution was
$$XZ^{2}=\sqrt{15^{2}-8^{2}}$$
$$XZ$$= $$\sqrt{161} = 12.7$$
but why?
Mathematics news on Phys.org
In the given triangle, we know it is a right triangle, and we know the hypotenuse is:
$$\overline{XY}=15\text{ mm}$$
And we also know the side adjacent to $\angle Y$ is:
$$\overline{YZ}=8\text{ mm}$$
Now, since the cosine function is defined as:
$$\cos(\theta)=\frac{\text{adjacent}}{\text{hypotenuse}}$$
we may then state:
$$\cos(Y)=\frac{8\text{ mm}}{15\text{ mm}}=\frac{8}{15}$$
And so we find:
$$Y=\arccos\left(\frac{8}{15}\right)\approx57.8^{\circ}$$
edit: To answer the added part, by Pythagoras, we know the sum of the squares of the legs is equal to the square of the hypotenuse, which allows us to write:
$$\overline{XZ}^2+8^2=15^2$$
$$\overline{XZ}=\sqrt{15^2-8^2}=\sqrt{161}$$
we may then state:
And so we find:
Thank you. Much clearer now. Since the question involves a right angle, we must use the Pythag Theorem. SOHCAHTOA helps a lot in solving for Y too! :D
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
