- #211
Jabbu
- 180
billschnieder said:Like I said earlier, there are no 0 events in actual experiments, because only detected photons count towards the expectation value. So the sequence above seems easier to type and discuss but bears no resemblance to anything that an experiment produces, at least any experiment that has ever been performed. If you think about it, that sequence is pretty incredible. To get a sequence like that, you need to know that two photons were emitted at the same time but neither was detected in some cases, and in others that two were emitted but only one was detected. In an actual experiment you only know what was detected. If you try to measure at the source, you destroy them and invalidate the experiment. If you detect only one, you can't be absolutely sure that another one was emitted but did not go through. So the 11 case is the only certain case for matches that you can have in any experiment. And even then you have time-tagging and matching to deal with, which complicates matters even further.
Then we shall talk only about splitter polarizers where photons are detected for both 1 and 0.
If you want to see some actual experimental data, see http://people.isy.liu.se/jalar/belltiming/ which has a portion of the Weihs data.
Looks good, but they are asking for $25. Could you copy-paste some of the data for 0 degrees relative angle?
