Why is it Impossible to Solve the Three Body Problem Analytically?
In summary, the 3-body problem, as well as many-body problems in general, are impossible to solve analytically due to the nonlinearity and chaotic nature of these systems. This is because nature is inherently nonlinear and the set of all possible functions is uncountably infinite. While linear models may provide approximations, they are unable to capture the interesting phenomena such as chaos and emergent behavior in these systems. Therefore, it is not a matter of lacking enough elementary functions, but rather the complexity and diversity of physical systems.
Dario56
290
45
Three (many) body problems where three or many bodies (particles) interact are impossible to solve analytically. First one appeared in classical mechanics where equations of motion of planets were tried to be found by applying Newton's 2nd law for system of planets and stars interacting via gravity. In quantum mechanics, problem appears in solving Schrödinger equation for molecules (finding a molecular wave function) which consist of at least 3 particles interacting via electromagnetism.
I am not sure why is solving such problems impossible to do analytically. I am guessing it has to do with the fact that we don't know enough elementary functions to be able to give a solution in closed form or simply that combination of elementary functions can't describe solution to many body problems.
What are your thoughts?
Likes Delta2
The short answer is that the general 3-body problem allows for chaotic solutions as proven by Poincaré. A result so fundamental that a recent approach rather interestingly simply models some 3-body configurations as random walks.
Likes PeroK, DrClaude and bob012345
In physics generally analytic solutions are a rarity. Laplace is often quoted as saying "nature laughs at the difficulties of integration".
Likes Delta2 and Dario56
Indeed. Nature is nonlinear at almost every level, with the set of realistic linear models having (waves hand) a measure of zero relative to the set of all models. The only reason linear models have "gotten" so much theoretical attention over time is because they are simple enough to be able to conclude a lot of stuff that, while interesting, at best only works as an approximation for the real world or in situations where we (e.g. via engineering) deliberately can construct parts of the real world to stay in the linear realm under some ideal conditions. But linear models are almost never able to capture interesting phenomenons like chaos and emergent behavior.
In fairness of the OP question I would like to add that the 2-body problem is (of course) not to be considered a linear problem, but (more handwaving) more like a degenerate nonlinear problem that has sufficiently few degrees of freedom for it to be unable to exhibit chaos.
Likes Dario56
Yes, this is certainly the case. Chaos means extreme sensitivity on initial conditions and it is impossible to express such sensitivity mathematically in closed form.
Non linear ODEs can be hard enough to solve already, imagine what we have when we have a system of tenths or hundreds of non linear PDEs, which are possibly needed to describe accurately many physical systems. Simply chaos lol (pun intended).
Yes well I would dare to say that no matter how many elementary functions we have we still won't be able to give closed form solutions to all the complex physical systems, because every such system requires its own elementary functions. And the set of all functions is uncountably infinite.
FAQ: Why is it Impossible to Solve the Three Body Problem Analytically?
Why is the Three Body Problem considered unsolvable?
The Three Body Problem is considered unsolvable because it is a complex mathematical problem that involves predicting the motion of three celestial bodies in a gravitational system. The problem cannot be solved using traditional analytical methods because it does not have a closed-form solution, meaning there is no single equation that can accurately describe the motion of all three bodies at any given time.
What makes the Three Body Problem so difficult to solve?
The Three Body Problem is difficult to solve because it involves three interacting bodies, each with their own gravitational pull and motion. This creates a highly chaotic system, where small changes in initial conditions can lead to drastically different outcomes. Additionally, the problem does not have a simple solution like the two-body problem, which can be solved using Newton's laws of motion and gravity.
Can the Three Body Problem be solved numerically?
Yes, the Three Body Problem can be solved numerically using computer simulations. However, these simulations can only provide approximate solutions and are limited by the accuracy of the initial conditions and the computational power available. As the number of bodies and the complexity of the system increases, the computational resources required also increase exponentially.
Are there any known analytical solutions to the Three Body Problem?
No, there are no known analytical solutions to the Three Body Problem. The only known solutions are numerical approximations or special cases where the problem can be simplified, such as when one body is significantly more massive than the other two. Even in these cases, the solutions are only valid for a limited time and cannot accurately predict long-term behavior.
Why is the Three Body Problem important in science?
The Three Body Problem is important in science because it helps us understand the fundamental laws of physics and the behavior of celestial bodies in our universe. It has applications in fields such as astrophysics, space exploration, and even climate science. By studying the Three Body Problem, scientists can gain insights into the dynamics of complex systems and make predictions about the future behavior of celestial bodies.
