Why is $\mathcal{A} \cup \{0\}$ Compact but $\mathcal{A}$ is Not?
  • Thread starter Thread starter lukaszh
    Compact
The set \mathcal{A}=\left\{\frac{1}{2^n};\,n\in\mathbb{N}\right\} is not compact because it lacks a finite subcover for every open cover, specifically illustrated by the cover \bigcup_{n=1}^{\infty}\left(\frac{1}{2^n},\frac{1}{2^n}+\frac{1}{10}\right). In contrast, the set \mathcal{A} \cup \{0\} is compact since it is closed and bounded, with zero being its condensation point. The confusion arose from misinterpreting the definition of compactness, which requires that every open cover must have a finite subcover, not just some. An example of a failing cover for \mathcal{A} is \left\{ \left( 1/n, 1 \right) \; : \; n \in \mathbb{N} \right\}, which cannot be finitely covered. Thus, the inclusion of zero in \mathcal{A} \cup \{0\} resolves the compactness issue.
lukaszh
I can't understand why the set \mathcal{A}=\left\{\frac{1}{2^n};\,n\in\mathbb{N}\right\} is not compact, while \mathcal{A}\cup\{0\} is. I know that set is compact if and only if it's closed and bounded, so in order to make set \mathcal{A} closed, we need to include zero, as it's condesation point of this set. Another definiton of compact set tells me, that the set \mathcal{B} is compact if we are able to construct finite cover of all open covers for this set. Now I'm constructing open cover for set A. For example open intervals
\left(\frac{1}{5},2\right),\left(\frac{1}{4},\frac{3}{2}\right),\left(-1,\frac{1}{3}\right)
and I'm able to find finite cover
\left(\frac{1}{5},2\right),\left(-1,\frac{1}{3}\right)
It's true that
\mathcal{A}\subset\left(\frac{1}{5},2\right)\cup\left(-1,\frac{1}{3}\right)
Where's the problem? Thank you.
Mathematics news on Phys.org
The problem is you misunderstood the second definition. It's not "compact iff you can find an open cover with a finite subcover", it's "compact iff EVERY open cover has a finite subcover".
aha, thanx. So, for example for cover
there's no finite subcover. Is it correct?
Indeed. In this case, for example, the open cover \left\{ \left( 1/n, 1 \right) \; : \; n \in \mathbb{N} \right\} does not have a finite subcover (why?).
If such finite cover exists, then for some N
\mathcal{A}\subset\bigcup_{n=1}^{N}\left(\frac{1}{n},1\right)=\left(\frac{1}{N},1\right)
That's not true, because there exists \frac{1}{N+1} which is not covered.
ThanX :-)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
