Why is my AM detector output distorted and only at 110mV peak instead of 700mV?
  • Thread starter Thread starter extremepilot
    Detector
The discussion focuses on an AM detector output issue, where the output is distorted and only reaches 110mV peak instead of the expected 700mV. The user is working with a Pspice simulation involving an RF amplifier and a simple envelope detector circuit. Initial calculations for the resistor and capacitor values were made, but the output signal was distorted and lacked a proper discharge path for the capacitor. After adding a 2Megohm resistor to improve the discharge, the distortion was reduced, but the output amplitude remained low. The user seeks advice on how to increase the output amplitude back to the desired level of 700mV peak.
extremepilot
Im working in Pspice, I have an RF amp with a modulated input signal coming in on ~600kHz carrier wave and an amplified signal coming out, here is what the output looks like 1Megaohm load after a blocking capacitor to isolate AC:
http://i.imgur.com/56NSI.png
I am trying to use a simple http://en.wikipedia.org/wiki/File:C_Simple_envelope_detector.gif" circuit after the RF amp without a load resistor. using t = 1/2*pi*f = RC with f=400hz and C=0.01uF I solved for R (4k). Here is the circuit:
http://imgur.com/09Dpk
and here is what the output out of the detector looks like:
http://imgur.com/TZSXA
Looks distorted if I am not mistaken and no where near the ~700mV output peak. What did I design wrong in the detector?
Edit: noticed I probed at ground node of detector but output signal looks the same at the top node of detector output.
C16 will charge up through D7 and there is no discharge path.
I don't know how it can charge up through D7 unless it's leakage current, I am guessing that's not causing the main issue , but how do I relieve it? High resistance to ground between C16 and D7?
I added a 2Megohm resistor between D7 and C16 and it looks like it took care of the slant type distortion. Not sure if this is right but I redesigned the detector with R as my 1Megohm load and solved for C.
The output signal is around 110mV peak now:
http://i.imgur.com/5oDbd.png
Can I get the amplitude back up to 700mV peak ?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
