Why Is My Physics Professor Giving Contradictory Advice?
  • Thread starter Thread starter Pork
    Bit Hi
The discussion revolves around a student experiencing confusion with physics problems and receiving contradictory advice from their professor. The student struggles with calculating work done and thermal energy transfer for an ideal gas during isothermal expansion and compression scenarios. They initially apply incorrect conventions for work and energy, leading to errors in their calculations. Other participants clarify the correct application of thermodynamic equations, emphasizing the importance of sign conventions in these calculations. The conversation highlights the challenges students face in understanding complex physics concepts and the need for clear guidance from instructors.
Pork
HI I'm new here. I've been having a little bit of trouble with a few of my physics problems. It seems like very basic stuff. I went to my professor's office hours and he didn't help me. He told me the wrong stuff, and when I emailed him back, he said different stuff.
1)
An ideal monatomic gas expands isothermally from 0.550 m^3 to 1.25 m^3 at a constant temperature of 610 K. If the initial pressure is 1.10*10^5 Pa.
(a) Find the work done on the gas.
(b) Find the thermal energy transfer Q.
The internal energy is 0J, therefor -W=Q. I tried nRT*ln(V_f/V_i) but that didn't come out. I'm not really sure what else to do.
2) A gas is enclosed in a container fitted with a piston of cross-sectional area 0.150 m2. The pressure of the gas is maintained at 5800 Pa as the piston moves inward 21.5 cm.
(b) If the internal energy of the gas decreases by 8.60 J, find the amount of heat removed from the system by heat during the compression.
I calculated the work done by using W=F*A*d, which comes out to be around -187. From there I tried using delta U = W + Q. Which would be -8.60=.187 + Q. However, my Q isn't correct, it is however within 10% of the correct answer.
1)
First of all I use the convention:
Q = U + W
If the gass expands, W is positive
1) W = nRT ln(Vf/Vi) = PV ln(Vf/Vi) = 1.10*0.550*105 ln(1.25/0.55) = 49.6 kJ
Q = W = 49.6 kJ
2) You are using your convention wrong. if U = W + Q, W is negative when gas expands, so, in this conventiuon, W = +187J and Q = -8.6 - 187 = -195.6J
You can use Q = U+W and it would give the same result
But in this case W = -187J, Q = -195.6J
Thanks for the help on those two. Any idea how to solve the work from these two graphs?
http://i.imgur.com/cRLxY.png
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
