Thalita Luna
- 4
- 1
That question has been puzzling me recently. But I know there is a simple answer to it.
It's possible, just not economically feasible. It's a combination of unpredictability (we can't put our lightning capture device where we need it when we don't know when and where the lightning) and the cost of building something that can handle a huge short-term energy spike without breaking.Thalita Luna said:That question has been puzzling me recently. But I know there is a simple answer to it.
You cannot do it all at once. But if you use a loop antenna at a distance, to capture part of the radiated magnetic pulse, you can charge a smaller capacitor or battery.Thalita Luna said:"Why is not possible to store electric energy from a Lightning?"
Baluncore said:but the strike will then avoid you, and hit your neighbour instead
280 kWh is also about the daily output of an acre of solar panels, another reason why no one cares about lightningruss_watters said:Also, google tells me a lightning bolt dissipates about a billion joules (1,000,000,000)! (zeroes and emphasis added by google). That looks and sounds like a whole lot, but it's 280 kWh (a month of electricity for a house), which is....some.
That didn't stop Dr Frankenstein:Nugatory said:It's possible, just not economically feasible. It's a combination of unpredictability (we can't put our lightning capture device where we need it when we don't know when and where the lightning) and the cost of building something that can handle a huge short-term energy spike without breaking.
Franklin captured energy from thunderstorm before actual breakdown (and was lucky not attract a lightning like Richmann).Vanadium 50 said:It is, c.f. Ben Franklin
You don´t need to keep your "loop antenna" at a distance. You might actually coil your antenna around - but insulated from - the lightning path, i. e. a lightning rod. That is, use a lightning rod as one "coil" or a transformer and wind another coil of transformer around it.Baluncore said:You cannot do it all at once. But if you use a loop antenna at a distance, to capture part of the radiated magnetic pulse, you can charge a smaller capacitor or battery.
To store all the energy in a strike, while the lightning current flows, requires you maintain the voltage, which is already above the breakdown voltage of the atmospheric insulation. Your device will therefore need better insulation than air, but the strike will then avoid you, and hit your neighbour instead.
I tried that about 35 years ago, when sensing the corona discharge through a lightning conductor to a ground mat. I used a toroid as the current transformer. Real lightning simply jumped through the air, around the outside of the toroid.snorkack said:You don´t need to keep your "loop antenna" at a distance. You might actually coil your antenna around - but insulated from - the lightning path, i. e. a lightning rod.
Yes, because that is a truism.snorkack said:Does bringing a lightning rod to ground even ground it?
Just because you build on "ground", i. e. "solid or pile or solids naturally piled on earth", does not mean that it is "ground" as in "low resistance conductor connected to the large capacitance of whole earth". And aiming to bury a copper ground mat "in a damp soil, near the surface", might be a contradictory goal if soil near surface is dry and insulating of electricity and groundwater and damp soil are far from the surface or absent. Or as I guessed, soil might be rock insulating of both water and electricity.Baluncore said:Yes, because that is a truism.
But not if you insulate the lightning conductor wire, or introduce an impedance. Then the velocity factor is too slow, so the fast lightning rise-time, goes around the outside, over the insulation.
Yes, when you bury a copper ground mat in damp soil, near the surface.
"I got this! I got this! ... I don't got this..."Baluncore said:I tried that about 35 years ago, when sensing the corona discharge through a lightning conductor to a ground mat. I used a toroid as the current transformer. Real lightning simply jumped through the air, around the outside of the toroid.
Because a lightning rod has a ground mat that is designed and engineered, to be a good conductor, to distribute lightning current radially and gradually deeper, onto the more conductive surface of the Earth. The radial wires spread out from a point on the surface, which results in a very low inductance. The circumference of the ground mat places the impedance of the radials in parallel with each other.snorkack said:Why doesn´t it happen all the time with lightning rods?
Lightning strikes are incredibly powerful but also extremely brief, lasting only a few milliseconds. Capturing this immense but short-lived energy burst requires technology that can withstand and manage very high voltages and currents in a fraction of a second, which is beyond our current capabilities.
A typical lightning strike contains about 1 billion to 10 billion joules of energy, which is roughly equivalent to the energy consumed by a 100-watt light bulb running continuously for about 3 months. While significant, this energy is released so quickly that capturing and storing it efficiently is a major challenge.
The main technical challenges include the extremely high voltage (up to 1 billion volts) and current (up to 200,000 amperes) of a lightning strike, the need for rapid conversion and storage of energy, and the difficulty in predicting exactly where and when lightning will strike to capture it.
Current energy storage technologies, such as batteries and capacitors, are not designed to handle the sudden and extreme influx of energy from a lightning strike. Additionally, the infrastructure required to capture and convert this energy safely and efficiently is not yet developed.
While it is theoretically possible that future advancements in materials science, energy storage, and electrical engineering could make it feasible to capture and store lightning energy, significant breakthroughs would be required. Innovations would need to address the challenges of high voltage and current, rapid energy transfer, and storage efficiency.
