I Why is Number-Flux Four-Vector Frame-Independent?
  • I
  • Thread starter Thread starter GR191511
GR191511
Recently I started studying 《A First Course in General Relativity》 and I came across a question in my book:
##\vec N =n\vec U##where n is number density,U is four-velocity,N is number-flux four-vector .The following sentence confused me:
In Galilean physics,number density was a scalar,the same in all frames(no Lorentz contraction),while flux was quite another thing:a three-vector that was frame dependent,since the velocities of particles are a frame-dependent notion.Our relativistic approach has unified these two notions into a single,frame-independent four-vector...
I wonder Why the number-flux four-vector is frame-independent?
All four-vectos are frame independent
You should read page 88 (in the second edition) where it is explained what 'frame independent' means in this case
Likes GR191511, dextercioby and PeroK
Because it's a four vector. They're frame independent by construction.
I think what you need to do is convince yourself that ##nU^a## actually represents something meaningful, and that it represents something meaningful whether ##U^a## is parallel to your frame's timelike axis or not. The usual way to go about it is to imagine a very large number of particles each with velocity ##U^a##. Then convince yourself that the number of particles crossing an infinitesimal plane depends on the number density ##n## and the velocity field ##U^a##, then convince yourself that the transformation properties of ##U^a## supply the right factors of ##\gamma## so that the transformed flux density behaves as you expect.
Likes GR191511, PeroK and vanhees71
The components of the 4-velocity are still frame dependent even if the 4-velocity itself is an invariant geometric object. This means that also the number density itself is frame dependent in relativity (##n## is the number density in the rest frame and is a scalar) just as the flux, which is number density times velocity just as in Galilean spacetime.
Likes GR191511, PeroK, Ibix and 1 other person
Yes, and that's why one defines (!) such medium-related "intrinsic" quantities in the local rest frame(s) of the fluid and thus becoming a scalar. That holds also for thermodynamic quantities like temperature or chemical potential.
Likes GR191511 and Ibix
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
