Why is the 1/2 important in the equation Ek = 1/2mv^2?
  • Thread starter Thread starter FakeGeek
The equation Ek = 1/2mv^2 defines kinetic energy, where the '1/2' is crucial for accurately representing the relationship between mass, velocity, and energy. This factor arises during the derivation from the work-energy principle, specifically when calculating work done on an object. Without the '1/2', the equation would incorrectly suggest that kinetic energy increases linearly with velocity rather than quadratically. The inclusion of '1/2' ensures that kinetic energy reflects the correct physical behavior of moving objects. Therefore, Ek cannot be simplified to mv^2 without losing essential accuracy in its representation.
FakeGeek
ok..so we know that Ek is by definition 1/2mv^2.
my question is that since Ek is simply defined to be that much..why does the 1/2 matter..
cant we simply write it as Ek = mv^2?
The '1/2' comes into effect during the derivation of the formula for Ek using the basic definition of work done.
Likes adib npm
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
