MHB Why Is the Containment xR ⊆ x1R Proper in Lemma 4.3.10?
Math Amateur
MHB
I am reading Paul E. Bland's book, "Rings and Their Modules".
I am focused on Section 4.3: Modules Over Principal Ideal Domains ... and I need some help to fully understand the proof of Lemma 4.3.10 ... ...
Lemma 4.3.10 and its proof read as follows:https://www.physicsforums.com/attachments/8283
View attachment 8284I do not follow the strategy of the proof ... for example Bland writes:
" ... ... Thus, $$xR \subseteq x_1 R$$ and we claim that this containment is proper ... ... "But ... why is Bland proving that this containment is proper ... what is the point ... how is this furthering the proof ...?Peter
He wants to construct an increasing chain
$$xR \subsetneq x_1R \subsetneq x_2R \subsetneq \cdots $$
in $F$, in which each containment is proper.
But he clains that $F$ is noetherian (by prop.4.2.11) and therefore this chain must terminate.
Thanks for the help, Steenis ...
Appreciate your assistance ...
Just a further point ...
At the end of Bland's proof we read ...
" ... ... If the chain terminates at $$x_n R$$ then $$x_n$$ is primitive ... ... " Why/how does the chain terminating at $$x_n R$$ imply that $$x_n$$ is primitive ... ...?Peter***EDIT***
Thinking about it a bit more I suspect that if $$x_n$$ is not primitive then we can extend the chain by showing $$x_n R \subsetneq x_{n+1} R $$ ... but ... contradiction! ... the chain terminates at $$x_n$$ ...
Is that correct ... ?
Peter
Yes correct. If $x_n$ is not primitive then $x_n = x_{n+1} b$ with $x_{n+1} \in F$ and $b \in R$ is not a unit. And then $x_n R \subsetneq x_{n+1} R$. The same argument is used a few times in the proof.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
